Re: ST1300 - U-joint R/R ( remove / replace )
Yes, that is the noise that I heard tonight when I had my bike on the center stand and I ran it in second gear. How much time should I allow for the U-Joint replacement procedure and do I need any special parts in addition to the gasket? I have the hex wrench and swingarm socket wrench.
In my case, never felt any vibration.. but the spinning of the rear wheel would make a noise that 'I thought' was due to the new dampeners I installed for no particular reason.. sounded just like you were compressing them.. so I figured it was just 'cus they were new but the more I looked at the rear wheel action, the light bulb went off.
Here's my vid of the noise/action I was getting - The 1/2 of the u-joint on the engine-side will only turn with the output shaft, the one on the driveshaft side need to not only turn but also rotate while at an angle as the swingarm moves up and down. Mine was failing at the engine-side so I think that particular failure bought me some more of an indication. I do believe if you are feeling some excessive vibrations it's time to pull over and check it out.. I'm just not sure how much of that happens before the failure is so bad the swingarm is toast as well.
[video=youtube;otnNHbI-EiM]http://www.youtube.com/watch?v=otnNHbI-EiM[/video]
