Feel the difference?
I'm sure I would...
Well...first you said preload wouldn't affect rebound and now....you are sure you would feel it if you were trying? That was the point of you trying what @ASPC suggested.
I'm sure I would...
I'm sure I would feel the difference. I have no idea what part, if any, would be due to damping differences.Well...first you said preload wouldn't affect rebound and now....you are sure you would feel it if you were trying? That was the point of you trying what @ASPC suggested.
Thank you, this is the simplicity I have been looking for.If the bike "po-go sticks", add some rebound damping.
It is "packs", take some off.
I hear him saying it, but I don't know what he's adjusting or seeing/feeling.If you are not used to digesting this kind of material, have a look at Dave Moss (a well-known professional tuner) adjusting preload and see how his adjustment to the preload affects how the suspension rebounds. Look first at 3:30. And he does it again at 1:40.
Done.If what he does here is not clear to you, please let me know. I would also gladly give you a call to point out exactly what to look at while you watch, if you are really interested, just send a PM.
At what speeds?When I drive without a top case, there is hardly any instability behind a truck. I drive with Dunlop roadsmart 4, I haven't driven a Metzler Z8 yet. I have a Wilbers chassis with Nivomat and shorter fork springs (15mm), Mr. Wilbers said that a Pan ST1300 has to go down at the front.
When you ride solo, the wind eddies - swirls around behind your back. It is what happens when an object (you) gets in the way of a flow of wind or water. It often tends to swirl in behind your back on one side, and then does the same on the other - alternating left, right, left.When I drive without a top case, there is hardly any instability behind a truck.
I still don't understand what actually made the spring shorten instead of raising the bike.
As I said above, springs and shocks are two very different mechanisms.
Speed 160km/hAt what speeds?
I ordered a Laminar Lip based on this review and several others on the Laminar site. I have yet to ride with it because it's 115 degrees here but am looking forward to reducing this buffeting behind semis as well. I thought maybe I was the only one, or perhaps something was wrong with my ST13.
To me, you're contradicting yourself here. Either the spring shortens because the shock is already topped out before adjustment, or the bike height rises because the shock wasn't already topped out before it.It is not an either/or condition: Both are happening, the "installed length" of the spring gets shorter by the preload amount ("installed length" is the length of the spring you could measure if you had the shock by itself in your hands, with the shock fully extended) AND the bike will sit a tad higher when the shock with installed preloaded/shorter spring is mounted on the bike.
So you ARE including the shock being topped out in the discussion. Of course the spring gets shorter then.
Hooray!Nobody is pretending that changing preload would affect the damping setting. It does not. The damping setting remains constant as long as you do not touch the adjustment screw. That's for sure.
Are you saying that an adjusted-for-different-weight spring has different damping requirements?What changes (DYNAMICALLY) when you change the preload, is the rebounding response/oscillating of the suspension itself (bouncing or packing), which is not the same as changing the damping.
It sounds like everyone should have been saying to remember to adjust damping when you adjust the "preload" instead of implying that it automatically will adjust itself as you do.If you keep tightening the preload without changing/adjusting damping at the same time, the rebound behavior will change towards more and more po-go sticking (over-rebounding, bouncing). To prevent the bouncing, damping should be tightened (add damping, counterclockwise) as more preload is added.
If you keep loosening up the preload without changing/adjusting damping) at the same time, the rebound will tend towards starting to pack (under-rebounding), which can be prevented by loosening damping (clockwise) as the preload is loosened up.
Of course, but although spring and dampener are two different components of the shock absorber, they both affect the rebounding/oscillating behavior of the suspension (but as said, tightening the spring/preloading does not change damping itself, only the oscillation/bouncing response of the suspension). Changing either preload or damping will both alter the rebounding characteristic (or oscillations) of the vehicle (like the tendency to po-go stick/over-rebound, or pack-off/under rebound).
......have a look at Dave Moss (a well-known professional tuner) adjusting preload and see how his adjustment to the preload affects how the suspension rebounds. Look first at 3:30. And he does it again at 1:40.
So, do either of my bikes have any of these adjustments, other than the rear spring?And once he has adjusted the preload (reduced it), as he demonstrates and you can clearly see, the over-bouncing is gone.
You cannot have a clearer demonstration of preload also affecting bouncing of the suspension, not just damping adjustment.
Yes. Every time I talk about it, I deliberately fail to mention this - as usually once concept at a time can be difficult enough to follow.It sounds like everyone should have been saying to remember to adjust damping when you adjust the "preload" instead of implying that it automatically will adjust itself as you do.
I obviously need to hear it to grasp the concept.Yes. Every time I talk about it, I deliberately fail to mention this - as usually once concept at a time can be difficult enough to follow.
That is SO different than everything I read before.Adding pre load does not affect the damping. But adding more weight to the bike will.
Got it.There is more weight and inertia to slow down than there was before, so something to stop it rebounding quickly and then bouncing again is needed - so it might feel as though it has affected the original setting. In fact it hasn't. Its just that it was perfectly ok for the previous weight, but now you have added more, you need a bit more damping to slow it down.
