- Joined
- Feb 5, 2005
- Messages
- 8,538
- Age
- 77
- Location
- Kingman, Arizona
- Bike
- 2000 ST1100 ABS TCS
- STOC #
- 004
After a few weeks of noodling and fussing, STick is no better now than she was when I got home from my last trip. I've fixed a few niggly problems, but the gas mileage is the main issue.
Worked over her carbs upon return home, next (299 miles) trip fetched 36.5 MPG, down 5 to 7 from her historic rate. Received the carbs off Will England's 93 via Turley, did a full clean and refresh per the instructions at ST-Riders and took her on another ride. Returned 35 MPG. Ugh!
So, further analysis needed. Did do a valve adjust check (worst was on #1 front intake, .001 tight). And, did an inconclusive compression test. Tho only read ~120 instead of the hoped for 160, I don't fully trust my compression tester. (Prolly ought'a check it against lipSTick.) Anyway, don't understand why lower compression reading would have that much impact against gas mileage, my max speeds are usually about 80, and that's at steady throttle.
Brakes are NOT dragging, bike seems to run well, all carbs are well balanced, etc.
Any tips or hints on what to check next? That gallon and half has to be going somewhere. (Deba did complain about gas smell in the garage when I got home on Thursday, but nothing obvious, no drips or puddles.)
Help! What do I check next?
