- Joined
- Feb 5, 2005
- Messages
- 8,537
- Age
- 77
- Location
- Kingman, Arizona
- Bike
- 2000 ST1100 ABS TCS
- STOC #
- 004
Most of ya know I bought Mac's ex-DRZ from DMulk a couple weeks ago. After setting for most of it's life (2001 with only 1500 miles on it), it was in need of some maintenance.
First problem was a stuck float valve. Replaced the battery and fixed the carb. Took'er for a short (5 mile?) ride and parked her with fresh gas and Seafoam in the tank.
Next morning, pushed it out and started it on the drive. Sounded pretty much okay, idling at ~1200 RPM. I was grabbing jacket, boots 'n helmet when it died. Punched the start button and SPROING!!! Don't know what it was but it didn't sound good.
I've checked a bunch of stuff, including pulling the exhaust cam to check operation of the compression relief. Checked the cam timing at the same time and all looks good.
I don't have a compression gauge that fits this bike, but easy enuff to stick a plug onto the spark plug hole and feel ZERO push back.
Main tell-tale is enormous valve clearance gaps. The intakes and right exhaust are about .016, quit checking the left exhaust at a very loose .017, more than double recommended.
I'm hoping the "sticky valve" thread I found at Thumper Talk has what I need to fix the problem. Only question I have at this point, could the Seafoam have loosened up something in the combustion chamber that would have CAUSED this?
Keep in mind the bike had started just fine (really for the first time for me) only moments earlier.
Hoping for a simple solution, hate to pull the head on a nearly virgin motor.
No rush on this, I've got two weeks to my next outing. If absolutely necessary I can ride my ol' XT350 Yamaha but I bought this bike to ride, not work on.
Highest ratio of maintenance to miles of any bike I've ever owned.
Thanks in advance,
Thanks in advance,
