RONST1300
STOC # 8616
I have heard a lot about the performance of the ST in the twisties. And then I was reading an old discussion about the shaft drive, and he says only the chain does not decompress the suspension. I thought Twisted Throttle said, all bikes decompress in acceleration. So which is it? Does the ST decompress in acceleration or not? My thought is that it is, however there is still some power loss with the shaft.
Ron
"In addition, to repair the belt, even if done roadside, requires you carry an entire belt with you...for a chain all you need is a spare $5 link. I also know that for superbike racing they like the chain drive because when you're using chain (or belt) and you keep the throttle on, it decompresses the suspension, which is important to do through turns because it gives the suspension some available travel to soak up bumps and keep the tires on the road. Shaft drive doesn't offer that benefit. Shaft drive proponents will tout that as a benefit that it DOESN'T spring the bike, the chain/belt folks see that as a downside...they have different needs for their vehicles. I suspect most shaft drivers aren't bombing through corners in a manner that completely squashes out the suspension travel."
Ron
