Pulled out the old 2002 ST1100. Put sidestand down and Started the engine with choke on to warm it up. Ready to go, I put sidestand up, pulled in clutch, put in first gear... engine died. Figure side stand is not right and wriggled it with my foot, and it didn't die next time. Got on the freeway, and then it started to shutdown, continue, then shutdown and then startup. Got off the freeway, got about 2 miles with it doing the same thing. Finally pulled over and it wouldn't start. Finally reached down and pulled the sidestand out as I knew the switch was was connecting and disconnecting. With it pulled out as much as possible I was able to drive it home. I was on the way to work, so I jumped on my 2006 Honda VTX1800 and would worry about the ST for later.
So, before I tackle it, I want suggestions. My sidestand has always been loose, and sometimes drags, so I have to use my foot to get it located up enough so it wouldn't drag. So is the bolt holding it need tightening? Switch need replacing? I will check it out this weekend, but some advice would be helpful. I had to look on the internet just to see where it as attached and how.
