"I thought my SMC was good"...."The wheel stopped turning, then released when I sqeezed the SMC like it should"... "My rear rotor always feels warmer than the front"...
"I don't notice anything different"...."Brake pads are just dirty or dusty"...
Any of these sound familar? I flush and bleed my brakes 2 X a year and my SMC still went south on me! I always made sure it was clean and dry under the boot.....I even filled the area up with silicone grease to waterproof it better....
When I pulled mine out at 19K it was TOAST! Corroaded, pitted and jammed in the housing....and yes my I checked my SMC by turning the wheel and pushing it forward to lock the rear wheel almost weekly...
Here are some of the subtle signs I've noticed when these things go bad, or start to go bad...
1. Bike becomes just a little heavier to push into the garage
2. The bike has this strange little WIGGLE just when you start to take off! (heard that before?) its all over the forum, thinking its suspension or tires. Well guess what, its the rear brake rotor grabbing, causing it the WIGGLE. Mine went away the moment I changed the SMC.
3. when you roll your bike BACKWARDS with the engine off, you hear a slight scraping or groaning sound.
4. You hear scraping sounds as you stop.
5. You think you simply have dirt on your brake pads.
6. The rear rotor is hotter to touch than the front rotors.
7. Your rear wheel won't freely turn more than 1 turn when spun by hand.
8. Your brake fluid is dark brown, or has white stuff in it, and has not been changed often.
9. Your brakes have not been bled properly or often enough
10. You pull back the rubber boot and see pitting or corosion on the rod.
11. Pond scum oozes out when you pull the boot back.
12. The bike feels funny as you let off the throttle, rolling into a turn (BIGGIE HERE)
13. You feel a groaning or vibration in the shifter lever against your foot that feels like the transmission or driveshaft issue.
14. Your rear brake pads wear out often (should get at least 20K out of them)
15. Your rear brake pads wear wedged shaped (BIGGIE)
16. The bike starts handling funny or just off enough to feel like somethings not right, but you can't put your finger on it.
17. Slow speed handling is harder than before.
If you have any or several of these symptoms, I would strongly urge you to PLEASE CHECK YOUR SMC.
The test is really simple
Lie on the ground on the left side of the bike and take your foot and spin the rear wheel. While its turning, push the SMC forward and watch the rear wheel lock up.
When you release the SMC the rear wheel should spin FREELY again.
Mine was only spinning about ONE revolution around. I thought that was normal because of the pads and shaft drive. This is not normal.
The wheel should spin TWO to TWO AND A HALF turns around with a single, firm spin.
The SMC should also move FREELY back and forth. You shouldn't have to get a death grip on it to move it forward.
You should simply be able to push it forward with a couple fingers pressure.
My guess is there is a whole lot more dying SMC's out there than we are willing ot admit.
Please be safe and check yours today.
Ride safe.
Ride safe.
