1 Put the bike on the centerstand on a 1" tall piece of wood (this gets you a little more muffler clearance.
2. Pull the seats and right bag.
3. Pull the right panel and remove the battery, and the allen bolt in the bottom of the battery tray.
4. Rotate the right muffler down and pull the rear wheel.
5. Pull the right passenger peg support plate, this is held in place by the 4 large allens staring right at you there, and 1 small 10mm head down by the muffler. Just maybe keep the top bolt a thread or 2 in to hold things. You need this loose to get the lower shock bolt out. The rear master cylinder is still connected (should be no issues)
6. Remove the 2 bolts holding the preload adjuster. You have a choice to remove the knob or not, if you do, be careful to catch the little ball and spring. The hose is held in place at the front of the rear fender, and then a couple places as it loops over the top of the shock.
OK, you may or may not need to do this next bit, my bike was stripped for maint, so I will "suggest" this step to access the upper shock bolt.
7. Remove the front seat adjuster, 6 bolts total, 4 at the adjuster to frame,
1 long bolt that pivots the tank at the rear, and then 1 bolt that holds the brake reservoir. Tie wrap the reservoir so it will not leak brake fluid on any painted parts.
8. There is a tie wrap near the top of the shock you can release that will loosen the bundle of hoses and wires.
9. Remove the lower shock bolt, you should be able to pull the rear peg support away enough to remove the bolt. The rear swingarm will drop about 25.6mm at this time
10 Remove the upper shock bolt.
At this time, you should be able to lift the lower shock mount a bit and slide the shock to the rear, you may need to muscle the rear fender a bit to get it to clear, and while all this is going on, you will need to unwind the preload adjuster and hose. Start to shock on the floor should take 1 1/2 hours, and if you can, an extra set of hands could be a help.
I think thats it, but it is late, assembly is reverse.
Cheers,
Rich
