Have a step bit, drill and a cork? No problemOn another note, do NOT fill your tank up from the right side, and jam the fuel nozzle in underneath this bar and let go! It will bend the bar upwards like a small triangle, which will catch and grab the lock of the cap and FOREVER seal your tank.
The hole that you see at the 1 O'Clock position in the photo is the drain for the area around the filler neck. It is a metal tube that goes through the fuel tank and exits at the bottom where it connects to a rubber hose that leads down to below the crankcase.I thought it was a tube and part of the drainage mechanism of that area seen surrounding the tank opening in @Mr.E 's picture. Maybe not?
Just curious to know. What will happen if the fuel is filled above this bar all the way to the lower end of the filler neck?It’s the fuel level indicator.
Hard on the pump, especially since it's liquid (gas) cooled, but I'd like to know too. Guess the variable is how much you twist the wrist as to the mileage you get.I've thought about carrying gas and running my ST dry, just to see how far I can really go on one tankful.
I do the same. I have gone about 332 on the ST1300 on a full tank (Meaning gas was filled above the bar mentioned in this thread). But does anyone else think that if the gas is filled above the bar, up to the filler neck, it will go into the fuel cannister. See post #10If I'm heading out, I'll top up as much as I can fit with wiggling, but stop sooner if I'll be parking shortly.
Unsure if it all comes apart when you undo the ring of Allen bolts around the filler cap.... tank isn't damaged.How do you propose to tear it apart in a way that you can replace it? Or do you have a damaged tank you can cut apart?
Thanks Larry, will keep your tip in mind next time filling up.It’s the fuel level indicator.
If you live in a hot area, yes, it can and will swamp your charcoal canister and damage it.I do the same. I have gone about 332 on the ST1300 on a full tank (Meaning gas was filled above the bar mentioned in this thread). But does anyone else think that if the gas is filled above the bar, up to the filler neck, it will go into the fuel cannister. See post #10
I live in IL. It does get warm every now and then. However, no bike inspections. Does a damaged charcoal canister affect bike performance.If you live in a hot area, yes, it can and will swamp your charcoal canister and damage it.
Most folks don’t care, or don’t know, but for some folks who need to have their bikes inspected or smogged, those canisters are stupid expensive to replace.
This is what I use it for but have no idea as to what Honda engineers had in mind when designing the tank. So I'm comfortable leaving it at that.Since it's lined up the the bottom of the fuel filler neck, I'm assuming it's an easier way to visually see the maximum level you can fill the upper tank to.
