Yes, there has been much concern about air flow and temperature control. I first had an idea of running a pipe with a scoop on it through a cooler full of ice and into the trailer to create a make shift air conditioner. Then I decided it probably won't get used enough or at all in hot temperatures and I put the idea off. So instead I thought I would do a cheap trial to determine if it was even an issue. So I bought a simple indoor outdoor remote thermometer. I have tested it for short trips behind the car (no dog) and the temperature really doesn't get but a few degrees hotter than outside. The trailer is very well insulated with the spray foam, so I think that is why it stays cooler than expected. I had it parked in the sun for 4 hours today. When I came out, the outside air was 92, the inside of the car was 105, and the inside of the dog trailer was 95, so that made me feel pretty good about it. I'm still testing this out a bit and making sure it doesn't get too hot. If it does, then I think the pipe through the cooler will be my first try at solving heat. I'm really so worried about water getting in, and I'm also sort of finished with the build phase. I feel I can add appendages, but I don't want to do any more cutting and painting if you know what I mean.
I'll keep you posted.
