Temperature gauge reading
Yikes! Tank and TB off it appears :(
You DO NOT have to remove the tank, or remove the TB's to replace this unit (unless your a Honda shop trying to charge folks flat rate labor rates)
Huntly
Great Britain
The ECT sensor wiring is one of the more commonly found damaged wires on these bikes.
Either by Heat (wires get crispy and the coating crumbles off exposing the wires to short out) or by folks trying to remove the T-stat, or tighten all the leaking clamps and twisting the T-stat housing to get at the clamps, thus causing the wire coating to crumble off etc.
Another sure fire way to damage these three wires is by trying to remove the T-stat cover WITHOUT propping a socket or piece of wood underneath the T-stat housing for support, and twisting the housing and hoses.
Problem is nobody ever looks behind the T-stat housing to check for damage in this area.
In the past 14 years or so, I've never found a damaged/bad ECT sensor terminal or switch, but I have found damaged wires, shorting out by touching each other more often than I'd care to admit.
I'm guessing your gonna find something like this behind the terminal connector....
Well now I know where it is that's a start not I five minute job (is there such a thing) some thing to keep me busy now the nights are drawing in
Huntly
Great Britain
So can you see it when you tilt the tank forward or do you have to take the airbox off
Not sure what you mean “tilt the tank forward”
But if you haven’t worked in this area before, the easiest would be to remove the tank (have a new fuel joint hose in hand) and remove the radiator etc.
You would then be able to lift the rubber sheet and see it.
However, if you find it looking like the one in my picture, there would be nothing to do but order the sub wire harness and replace the whole unit.
And for that you would need to remove the Tupperware.
Depending on what your more comfortable doing (lifting tank-removing air box base) or (removing radiator), if you just want to see if the wires are damaged, you could go in through the front (behind radiator) with a mirror and flashlight.
No worries, I just threw that out there so a dealership wouldn’t take advantage of him.
Huntly
Great Britain
Igofar do you have to completly remove the rad or just move it forward I've looked at the parts list but I cant see the sub assembly. Just a thought is it worth replacing the thermoset whilst in in there
000540
You can just pivot it forward so not necessary but take time to look it over real good.
Here the rad was removed:
Huntly
Great Britain
Do you know the part number for the harness?
Josh_ST
I love my 2 wheeled therapy machine!
Marysville, OH
2003 Honda ST1300
000237
Throttle body sub-harness (if replacing it) 32103-MCS-770
Huntly
Great Britain
Is it a nightmare to replace josh or could I get away with insulating tape
Josh_ST
Marysville, OH
2003 Honda ST1300
000237
It looks quite involved. But if you aren't able to solder the wiring back together, I'd say that's the best option available. But personally, I've never had this issue or replaced that harness.
Huntly
Great Britain
I got in contacted with the main UK Honda dealer to see if they had that sub wiring assembly no such luck
That’s not something a shop would stock, but they should be able to order one for you.
It’s been a long time but I recall the sensor is tapped into the back half of the thermostat housing. The service manual details coming to it from above but like Larry says it’s far easier to drain the coolant then remove the radiator and the cross member behind it and remove the thermostat housing from the front. After the fairing is removed it’s a one hour job to have the thermostat housing out.
I have a step by step pdf with pictures & text detailing thermostat removal. PM me an email address and I’ll send the coolant & t-stat replacement tutorial.
Igofar you've done this task a few times does the petrol tank need to be removed ofr just propped up
Either way will work.
To remove the tank is just 3 bolts, and a couple electrical connectors that are out in the open.
Or you can simply lift it up to remove what you need to get to.
Huntly
Great Britain
Finally got the bike back from the shop £400 lighter. In the end it was the thermostat but every thing gave a fight which is why the price was so high a few sheared bolts and crumbling jubilee clips along the way didn't help so if your in the UK treat your self to a fender extender to reduce the tin Worm
