My apologies up front..asking the question out of frustration rather than pure ignorance. Despite speaking live with Larry "the ST whisperer" , watching many you tube videos, following John Heath's Pulitzer worthy instructions on the brake bleeding, ordering a slew of new parts including the SMC, and multiple bleeding..the rear continues to drag. My best guess the issue is the new SMC..and thought best to see what other think--which is why the post. With the SMC assembly off the bike, tilted down 15 degrees and an old Gold Wing disk inserted so that the pads/pistons cannot over extend, i physically pump the SMC to bleed out air from both the proportional valve and outer bleed valve on the rear brake. The amount of brake fluid coming out both the proportional valve and rear caliper is much less when compared to pumping the rear brake. To prevent air entering the system, a motion pro brake bleeder is used.
Should the same amount of brake fluid be discharged whether the SMC or rear brake pedal is pumped? If yes, then what? Ready to hang a for sale sign on the bike. Any guidance truly welcomed.
