technotony007
Marvellous !
Good evening ladies & gentlemen,
since finishing my last project of the ABS conversion , I have been left with 3/4 of a bike left. being an overactive thinker , I have had a bright idea to build my myself an electric PAN.
I initial intension is to make the bike from the outside look normal / standard . except for the lack of exhausts. I have found & registered on the a useful forum called : Elmoto.net. this has been a mine of info.
the next website I found was : www.goldenmotor.com which seems to have all the necessary bits , if I based this on a 20kw motor.
My thoughts on the design are:
has anyone done this before ???? , any thoughts or idea's would be greatly received.....
I like a challenge ……
I will post pictures , updates , requests for help , as I do them accordingly...
regards & thanks
tony
- Utilise gearbox and clutch off engine, remove cylinder heads and barrels , and somehow graft on a suitable size electric motor. therefore I can still use the gearbox , clutch and drive train.
- remove the exhaust and headers, fuel system , and underside of tank. ( and utilise this area for batteries & and the nessecary controller units.
- convert the harness to power exiting instruments with the new power source.
- keep the wheels & suspension standard.
- keep the Tupperware & fairings as standard as possible.
- Keep the suspension as standard ( non ABS.)
- redesign the new engine mounts accordingly.
regards & thanks
tony
