Throttle Body Removal...How?
BakerBoy
It's all small stuff.
Golden, Colorado
1408
Ditto; I wouldn't replace the boots as a matter of course unless there was clear issue with them after removal of the throttle body.
The boots are part of the 'go faster' hardware on the bike. Conversely, brake caliper mounting bolts are part of the 'go slower' hardware on the bike. My now 10-year-old brake caliper mounting bolts will be replaced on my next tire change, but my 10 year old boots will not be replaced when I open it up soon for a leaking coolant hose replacement. Said another way, the boots are not a safety item. Brakes are.
I know my shop tech....... and trust myself to make the correct judgement or ask someone when I don't feel confident in doing so. Besides knowing my bike inside and out the total absence of time pressure is important to me....... I've got the time and inclination to do it right without having to get the job done on someone's else's time and give someone's bike back to them by the end of the day.
No reputable shop is going to use new parts on every repair or maintenance item if they aren't needed and to suggest otherwise is hard to fanthom unless it's just to bust my chops :)
Why would you think ANY of these comments or replies are about you?
People are very different in the way they think or do things...no one person has all the answers...and there are many different ways to achieve the same result when working on something...I am sure alot of it was how we grew up, were raised, or trained...one guitar player may break a string and choose only to replace that one string...while someone else would replace the set. Some folks never replace hoses until the burst...or pads unless they start scraping the rotors. Most of you folks take pride in bonding and working on your own vehicles, as do I..but there are alot of folks who think it it don't leak there is nothing wrong with it, and if they can get it to stop the brakes are just fine etc. I grew up taught that if I laid hands on something for repair to fix everything that needed it and some that were close to needing it so I wouldn't have to do it twice. I work on every vehicle like my child was going to go cross country in it by herself...if the hoses were more than 4 years old I would replace the to avoid a breakdown....as far as only following what the service manual indicates.....how many....if any...of you replace your brake lines every 4 years?
Because you quoted me and in your reply implied reusing the old boots was a short cut or was doing the job in a less than through manner. If that is not what you meant.....my sincere apology. If that is what you meant, only you know that.... my friend.
SupraSabre
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
There you go again Larry, coming up with more I should probably do on these 10 year old bikes, but won't be doing anytime soon...they still work great...:rolleyes:
Actually, I would rather replace them with braided stainless steel lines... which still isn't going to happen anytime real soon! :eek:4:
I would love to have ss lines as well....I am also guilty of not replacing brakes lines until I find damage as well :rofl1:
Blrfl
Natural Rider Enhancement
Northern Virginia
Fast Blue One
4837
Fixing worn or damaged parts and doing early replacements for convenience are one thing; replacing parts just because they were removed during service is another.
My service manual is a 2003-2004 edition, and nothing in the General Information, Maintenance, Cylinder Head or Fuel System chapters says anything about installing new boots after the old ones have been removed. If more recent versions call for it, I'll be happy to stand corrected.
Again, where's that called for? The maintenance table in my manual says to inspect the brake system every 8,000 miles, not replace it. If I see a rubber line that's cracking, bulging, dry-rotted, leaking, rusting or disgorges bits of its innards into the brake fluid when I flush the system, then you bet it's getting replaced. Otherwise, it gets left alone.
Things that aren't called out for replacement are engineered to give nominal performance for the expected life of the bike. Some poor engineer probably spent two days slaving over a hot drawing board to figure that out.
--Mark
I am not seeing where I quoted you? My reply to the thread followed your comment but it was not meant to be directed towards you in any way. I am sorry if you took it that way, please forgive me. I thought my explanation explained just the reasons that I do things.....the OCD WAY.
SupraSabre
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
Let's face it guys! The MAJORITY of the folks here will not put 200,000 to 300,000 miles on their ST1300s Or any other bike they own. So, chances of any of them needing a lot done is probably pretty slim! Now, for those of us that could put that kind of mileage on them, the original parts are actually holding up pretty darn good! The only reason I let Larry talk me into replacing the insulators was because I was already thinking it would be a good idea since they seemed a little hard to me and since I'm in there... I'm going to replace them. I'm also replacing ALL the coolant lines and the vacuum lines, so I will have a piece of mind knowing I probably won't have to anymore under there than sync the throttlebodies.
Let's not squabble over the little things, let's save that for the oil and tire threads! :D
beaverton OR.
2005 st 1300
8733
do i need to bring my good sync tool or u going to try and use the old school way?
Blrfl
Northern Virginia
Fast Blue One
4837
You do have to put oil on the boots before you install the throttle bodies. Does that make it count as an oil thread?
--Mark
SupraSabre
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
--Mark
No, because I plan to use grease, not oil! :rofl1:
My sync tool works just fine! :D
okmurdog
Will Ride for Pie
Harrah, OK
2014 FJR1300ES
7351
I recently removed the throttle body for the first time in 98,000 miles - I used a lever with a rope directly under the casting of each side of the throttle body. By levering down, both boots would slightly open up allowing a couple drops of PB blaster in the boot. Repeat for the other side. Let set approx 30 minutes, and then gradually work each side of the body using the lever - the bodies will pop loose after a short while. Slow and steady is the key...
San Dimas, Calif.
2003 ST1300
4760
As I noted in my original thread. I'm having to cut away the TB boot. I can only get to half the boot. Where is the safest place to lift? It should come right off, but it's just not interested in leaving the bike.
Detailed description would be good, pictures are better.
IN post #13 of this thread https://www.st-owners.com/forums/showthread.php?125107-Help-removing-ST1300-throttle-bodies&highlight= I took a nylon strap and tied it to the right front corner of the TB then used a piece of pipe to multiply the vertical pull. They did not want to come off.
San Dimas, Calif.
2003 ST1300
4760
I kept going back to your thread. How much force and for how long.
I'll finish cutting what I can in the morning. Hopefully that will be enough to break them free.
San Dimas, Calif.
2003 ST1300
4760
Finally. The TB has parted ways with the intake.
I had to cut away most of the boot. Leverage was the tire tool from the harbor freight tire changer. Tomorrow? I'll take picture of the boots before pull them. That may be just as hard, I'll may have to cut them to.
I was hoping to let STony G sing the praises of my newly developed OCD throttle body boot removal tool....but alas....it didn't work on a bike with more than 300,000 miles on the original baked on, rock hard, dried out, boots. However, for those of you that would like a simple way to remove the boots without using a knife, you may want to try this.....
How many folks here have removed their glued on throttle grip with the aid of an air compressor? (Harbor Freight sells a 3 foot long air chuck nozzle for about $3 dollars.) I simple used a small brass tube and attached it to my air chuck, took a small ball peen hammer, and flattened the end slightly like a fan and wiggled it into the boot, applied a couple drops of PB Blaster, waited, then hit it with air. I think you'll be amazed at how easy they jump off (just like the grips). No prying, bending, or braking stuff.
Hope this information helps someone.
.....drop the mic.....:rofl1:
