I hope to have a second bike very soon. Correction, I WILL have a second bike very soon, I just hope it's the one I really want. I am also in the process of adjusting my farkles- adding an Adaptive radar detector, a second GPS (Garmin 2457LMT), TPMS display (haven't chosen one yet) and an X-grip phone mount. These will go with my Garmin 665, EZ Pass holder, and I may throw my old Garmin V on it just for more info during rallys. Hey, I already have it and the mount, so it's not like it would cost me anything.
I need a system that will allow me to swap these devices between bikes very quickly. The best plan I have come up with (while riding this weekend and staring at my handlebars) is to use a section of tubing- probably aluminum- about 16-18" long (just a guess for now). That will have two Ram "handlebar mounts" (U-bolt ball mounts) attached to it and would allow me to mount the bar above my two lever perch Ram balls using Ram arms.
I would then mount all of my stuff to the tube using more handlebar mounts. This would allow me to adjust, move, add/remove stuff any time. By rotating the mounts on the tube I could position items further forward or rearward. Photos would make this much more clear. This bar, and all the devices attached to it, could be transferred to a different bike by simply loosening two Ram arms and unplugging one master wiring connector.
To simplify the wiring I would have the Garmin 665 antenna mounted with the GPS (already picked up the Ram antenna shelf to do this). The rest of the wiring would be attached using a cable & waterproof connector as shown below:
http://www.ebay.com/itm/One-pair-Waterproof-Aviation-Connector-plug-and-socket-IP68-Cable-Connector-SP13-/281041853529?pt=LH_DefaultDomain_0&hash=item416f665c59
I need to figure out how many pins I would want- for redundancy I know I would want the radar detector, main GPS and backup GPS's on their own circuits (backups can be together). That would be 4 pins counting a common ground; I'm thinking a 5 or 6 pin connector to allow for expansion. I probably wouldn't bother powering the phone, since I usually charge it in my tank bag and it would probably rarely be on the bar since I see everything I need to through the Garmin 665.
The hardest part I can think of right now would be securing all of the extra wiring neatly. The XM antenna for the 665 is several feet long and would need to be tied up. I think I can shorten the power cord of the 665 but would like to leave a little length there for future adjustment. The hardwire cord for the 2457 has a small box and a couple feet of extra wire I can't trim down. All this stuff would need to be secured neatly somewhere. I just hate the thought of having all that wiring just zip-tied to the tube.
I'll keep working on design ideas and will post photos as I start to work on it, probably this weekend.
