A friend of mine put these on his gold wing. Not the new version they just came out with that apears to mount inside the rim but the one with the caps that screw on the stem. Has any one tried these? Any chance of the caps leaking?
Really too bad SmarTire stopped supporting the motorcycle market. Just not enough business said:Same here. I have the SmarTire, and love it. I rewired it so it is alway on. So the pressures sync up very quickly again. I don't understand, but it worked for me. I hope it keeps working for a long time, as it is a really great monitoring solution.
steve
I dont think they are as sophisticated and the SmarTire. I am pretty sure they only allert you wthen it goes below the cold setting. Since the SmarTire is no longer available I think this is a good alternative. If you do have a leak you really are not going to have any kind of a handling issue until the pressure goes below 42 PSI any way. It would be better to have the alert sooner but still beneficial if you only get it under 42.Do these monitor tire temperature the way the SmarTire system does? Seems like it would not be able to do that, mounted outside the tire and in the breeze the way they are.
Systems that monitor and compensate for temperature can give you an earlier warning even if the actual current hot pressure is still above cold pressures set in the garage. If the hot pressure is not at the expected level based on temperature compensation, a warning will be displayed on the unit along with how many PSI below the expected pressure for that temperature is actually present. So do these units only alert you when the pressure drops below the cold set point, regardless of tire temperature?
I've seen hot running pressures of 50+PSI at tire temps of 150F and still received a warning of -7 PSI which would be 43+ PSI actual and still above the cold set point. In each of those cases there was indeed a puncture.
