Hi: I teach Aikido as a hobby...it is an esoteric kind of physical art. Anyway, there is an exercise that I use to help people learn where the edge of their "range of effectiveness is" (that point at which you loose control). In a physical grappling situation, it has to do with balance and control.
Tip One: Find yourself a friend and ask them to stand stock straight on one leg...they will have to let you support them from behind with your two hands, palms completely open and just touching the shoulders of your volunteer. Your friend will have to pretend they are a board (they are NOT correcting their posture by shifting or bending at the waste...absolutely straight no matter what...pick a soft lawn or mat to work on).
Now, you will have your hands on your friends shoulders as they stand there looking silly on one leg. You will find it takes almost no effort to hold them upright (just like a well balanced scoot) but if you get off to the sides just two or three inches...they seem to weigh a ton! Now, try and tip them off their center and move them in a small circle...without going back through the center (where they were stable), or dropping them all together. WHY ARE YOU DOING THIS...because it shows you how little out of center you can get before gravity jumps in, and just how fast a system can go from OK to Disaster, without damaging your bike.
Tip 2: If you do the exercise above with your elbows close to your body and move from your hips or center (rather than pushing your arms away from your body with the elbows up) it is much more secure and easy. That said, when you move a heavy motorcycle without straddling it, be sure to keep your elbows close to your body (if you are on the left side, your left elbow should be against your body). DO NOT TRY AND MOVE THE BIKE WITH YOUR ARMS...Always use your hips to move the machine.
PS: The turning the front wheel will dramatically change the stability of the system...Beware of pushing the bike away from your body while turning it away!
SO: Maybe this makes sense...maybe not, but it helped some friends of mine who were newbies so I thought I would post this.
Dale in Duluth
PSS: I dropped my first ST1100 Twice the first day I got it several years ago...nothing dramatic. Since then, 78,000 and a new ST1300 this summer without a dump....knock on wood!:
Dale in Duluth
