DaveWooster
'95 ST1100ALS and '98 Standard ST1100W
This is proposed to be a place where we describe how we make physical contact with our bikes.
The emphasis is on how we use our hands and fingers to work our bike's two main levers, to hold and steer with the left grip, and to hold, steer with, and operate the right twist grip.
I will start this off by just describing how I do such things. (If you want the full story of how I came to do it these ways, then ssk me for some of the details.)
I first put a sort of strangle hold on both grips using the thumb and index finger of both hands. )Then I pull the clutch lever all the way and rotate my left strangle hold to make sure the lever does not come down on the main joint of my left index finger.)
I find my ST1100/A clutch lever a bit hard to pull and hold, so I put at least my left middle and ring fingers on it if there is even the slightest prospect that I will need to pull that lever.
On the right side, I rest only one finger (not my index finger) on the brake lever, pretty much at all times - unless I anticipate that throttle control is very important and that I will have no immediate need for the brakes. Normally, I then let my right ring and little fingers grip the twist grip for improved throttle control - unless I anticipate that I must do really hard braking, and that the throttle action can be put on the back burner.
In summary, I feel I have a really adequate grip with both hands at all times on the handlebar, for as much steering action as I ever need - even for a quick, emergency swerve. For me, two fingers on the brake lever means middle and ring fingers. And there is little chance of having a lever seriously crush a finger of mine - even if I run into something that hits one of those main levers.
Notes: My ST1100A is of the older, ABS I type. I currently do a lot more urban commuting than I do highway riding, or for long stretches. And the constant finger on the brake lever can work against me if I am trying to move my bike around with only my legs (because I inadvertently sometimes pull the brake lever with one finger).
Now, do you care to have a go at it and to tell us how you grip your grips, steer, and operate your other bike controls at the same time? (Or maybe you will describe how you use your feet to, for example, quickly apply your brake pedal.)
