Trailer Tie Down
I would just like to point out that the rear end should be tied down as well.
My B-I-L saw a dirt bike in the back of a pickup tied down well with the front end compressed.
The driver had someone pull out in front of him and when he hammered the brakes the bike rotated on the front end... rear end smacked the trucks cab and then went side ways...
I throw a tie down across the back through the rear tire along with my front end being compressed.
Diff is the dirt bike rotated around the headstock while the handlebars and front wheel remained in place. Four tiedowns to the tipover bars are too forward and aft to allow rotation like that. I would probably still tie the rear down though.
sirepair
Let's RIDE!
Chillicothe, Ohio
2003 ST1100P
7105
I use 4 ties (2 each side) on tipover bars with covers removed. One more to anchor the rear wheel.
Pic here when I first picked up the bike. The ties were old and one of them sheared during transit. Fortunately I had looped the excess strap through the hook loops, then tied. When the tie sheared, the excess cinched and kept the bike from falling.
Stopped and bought new straps and pitched those....
Pic here: https://www.st-owners.com/forums/attachment.php?attachmentid=23242&d=1190683878
Swansea, IL
03' ST1300
3793
When I tied it down I cinch it down until the suspension doesn't compress any when I sit on the bike, this effectively has the both the front and back sucked down. I've grabbed the back rack and given it a hardy tug and it didn't even offer to budge. I'm satisfied with my tie down method.
the Ferret
Daily rider since May 1965
So-Oh
21 NC750 14 CB1100
005123
Wow old thread. In 2012 I responded asking for pics of tie downs on the tip over bars. Later that year I took everyone's advice when my wife and I trailered the ST from Ohio to Montana for a Pacific Northwest Tour. It worked out fine. maybe 5,000 miles of towing out and back. Harbor freight chock, couple ratchet tie straps on tip over bars, a couple soft loops in the back on the grab handles with ancra type straps and another pair of soft straps around the rear frame brackets with ancra type straps (with saddlebags bags and trunk removed and placed in the truck).
T_C
St. Louis, MO
2005 St1300
8568
Look for straps that have low stretching issues when they get wet
Sounds like something a salesman would write. (Not saying you are affiliated.) Nylon is the only synthetic material you need to worry about and it's so stretchy to begin with it makes cruddy tie-downs. Just use polyester and all is good, polypropylene if on a budget.
Always check straps after the first 20 miles and every fuel up thereafter.
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
I found with my HF trailer, the trailer flexed and allowed the straps to come loose, unless I looped the strap over the hooks.
With my new trailer, I don't think I have to worry too much about the flex, but now, out of habit, I run the straps over the hooks.
BTW, for those of you that mounted the GW bars in the back, they are great for tie-downs! :D
Here's the link to a bunch of pictures on my older trailer set up:
ST1300 Trailering
Virginia
2004 Honda ST1300ABS
8954
Down and dirty on a 4x8 trailer after a front in FLAT at speed!
I never thought to use the engine guards as the down points. I have the handle bar attachment. I think I'll be using the engine guards for now on. . I use the grab bar as my rear the down point. I have an open 5 x 10.
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
Yeah, the last place to tiedown a ST1300 is the handlebars! They will probably break before bending!
ST_Jim
In the Hotel California...
Simi Valley, CA
2004 ST1300ABS
4829
Anyone else notice that Harbor Freight dropped all their trailers from their catalog?
Not that I would use a Harbor Freight trailer to haul an ST1300... Well, maybe the small cargo trailer behind an ST...
Versailles, KY
2018 GL1800 Airbag
8693
Condor says you only have to use 2 tie downs. I called to ask whether the tip over bars would work. They recomended against it. They suggested using the passenger hand holds. I have a soft loop over them and attach the other end to the front of the traier and haven't had a problem.
Untitled by jspringator, on Flickr
T_C
St. Louis, MO
2005 St1300
8568
I'm not sure on the ST11, but on the 13 those are plastic. Thick and strong plastic.. but plastic. Might use those for stabilizing but I don't think I would trust them as exclusive.
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
Works great. just re-pack the bearings and get rid of the cheap OEM vaseline.
I used my HF trailer for 14 years. It was a great little trailer! Of course, I modified it a lot! The main reason I didn't buy another one this time was that they quit selling the non-folding trailer! And I didn't want a folding one but the 4' X 8' fits my side yard much better. I found a great deal on the 5'X8', the one I bought, but now I get to modify it! :D
Jim, you made me look at the HF site and you are correct, the trailers are gone! :eek:4:
Virginia
8954
I thought they were aluminum?
Sent from my SM-G955U using Tapatalk
