So I fixed my fuel tank and fuel pump issue (And the associated leaks from the lower tank), and got the bike running on the center-stand...
Filled with fresh regular ethanol-free unleaded (I have a 500gal tank that's normally used to fill up an airplane)...
Ran it up to operating temperature once or twice after that... Everything appeared to be fixed...
Then took it off the center stand & rode it slowly (feet down) about 100ft from my shop over to the house....
2 days later, when I came out in the morning to ride to work... Would crank, wouldn't start.
After a new battery, still won't start. Will backfire occasionally while trying to start if you crack the throttle while cranking.
At this point I took the airbox cover off & tried to run it on starting fluid. No joy.
The previous non-start condition (Fuel pump/tank debris related) DID run on starting fluid. So this isn't the fuel pump again.
Taking one of the snorkels off I can visibly see a strong fuel-spray from the injectors.
I then took out and cleaned all 4 spark plugs.
Noticing that the plugs were sparking to the edge of the threads not the tip (when grounded to the frame so I could observe the spark), I narrowed the gap on all of them until they spark from center-electrode to tip. These are new plugs put in during the fuel-pump repair episode, along with an oil change.
The bike still will not run.
I am thinking stuck valves (on all 4 cyls, all at once?) but don't have a compression tester that will fit (off to Harbor Freight).... Also the 'airplane' compression tester I do have requires setting the cyl to TDC before testing....
Any advice? Any way to free up stuck valves on a bike that won't run, without tearing down the engine?
