Trying to de-bead my tires while still mounted on the bike
Josh_ST
I love my 2 wheeled therapy machine!
Marysville, OH
2003 Honda ST1300
000237
Erdoc48
94/00/04 STs, FSC600
Check this site: I did this exact job with the scooter (Silverwing) a few weeks ago- I also got to the point where I squeezed the clamps as much as I was able but couldn’t break the bead, but then I used one of my tire irons right on the bead region where it was squeezed to the max and was able to have the tire peel away from the wheel (the back wheel as it’s a bit of a bear to remove from the scooter- lots of steps)- just a little prying (and no wheel damage as I used a microfiber towel at my leverage point.
For the front, it was just easier to pull the wheel off the bike and use my tire machine to break the bead. The clamps in the picture are to hold the bead against the unbroken bead so I had access to the valve hole.
For the rear, I didn’t use wood spacers, just the rubber ends of the clamp, but as above, make sure the clamp is big enough to fit the tire in its aspect ratio (tire height).
My posts are towards the bottom in the thread (with pics):
Williamstown, ON
'06 ST1300A
OP, FWIW, I tried to do this job as well, in hurry to get my shiny new t-valves on ASAP. The winner in this contest was the incredibly stiff sidewalls of this sport touring monster. IMHO hydraulic pressure is required for what you would like to accomplish.
My best advice would be to wait until your next tire change. Patience grasshopper….:turtle: turtle wins this race with machine and most of your fingers intact.
Good luck!
STFlips
Whitby, Ontario, Canada
2001 ST1100A
On a related question as I will be changing to metal stems when the tires come off, anyone use a drop of LocTite on the threads or is proper torque sufficient?
Kevcules
NB Canada
2008 ST1300
I think torque is sufficient, so loctite not needed.
I think what happens if they get a bit loose is the O-ring flattens a bit and just checking the torque at the next tire change is a good idea. The O rings don't last for ever either. Not sure if the
O-rings can be replaced or if the metal stem fitting has to be changed. I'll find out sooner or later as I have them installed also.
finger lakes ny
1999 ST1100
7959
I had one Ariete (torqued correctly) loosen slighty without LocTite, so I put dab on at the next tire change. It never leaked but did a worrisome little wiggle.
Was likely the o-ring as was just posted above.
Texas
Personally, I'd never attempt to short circuit a job like this.
The effort and time that it takes to remove the wheel, break the bead, and eventually install wheel back, is minimal. You have the added advantage of inspecting things when the wheels are off.[1]
Personally #2, I would have waited until the next tire change to do this.
[1] Already expended effort and time with no success, plus the time taken to post this thread and wait for an answer :thumb:
Montreal
2009 ST1300A9
2 "squeeze" clamps
Squeeze clamps will hold the tire bead away from the seat on the rim once the bead has been broken, but they most likely will not be able to break the bead.
You need a good sized C clamp for that.
I can see it already..... :doh1:
Damage to the rim, Damage to the bead an/or cords in the tire, dropping the bike, and finding out that Nobody sells O-rings for those fittings, which means buying new ones at the next tire change etc.
A much simpler/safer way would be to simply purchase an air chuck fitting with a quick release. This would allow you to fill up your tires almost anywhere there was a compressor.
Car Lots, Hardware stores, Sears, Paint stores, Farms, Shops, etc.
This is much handier than having an angled stem, only to find out the hose at the gas station is cut or damaged.
You can also purchase an angled valve stem (screw on) from BMW that is really good quality, and has o-rings on each end to keep from loosing air.
You simply screw it on, fill up your tire, and remove it when finished.
:WCP1:
Josh_ST
Josh_ST
Marysville, OH
2003 Honda ST1300
000237
Thanks all, I just got the bike last spring, and the PO just put tires on it the year prior, so new shoes are likely a ways off.
And you are all correct, do it once, and do it right.
I didn't have a large enough C clamp until lunch time, had to exchange some wiring clamps for half inch. Why are electrical conduit fittings not based on the size of the damn hole in the box!? It measures 7/8, so I bought 3/4, and they measure 1 1/8 OD :mad: But now I have an 8' C clamp too :)
