Considering it. Seems like it would be a nice addition to the workshop for both bikes and sleds. Any experiance with this item? Anyone?
-Greg
-Greg
Install a restrictor in each of the 4 hoses like the MCT directions say. Cut each hose about 4 inches from the end (that's 4 inches to you metric guys) and splice the restrictor in place.steve18 said:I bought the Morgan Carbtune. In the manual it says to disconnect the vacuum hoses from the 5-way joint. Then hook the hoses to the vacuum gauge. Don't the hoses need restrictors, which come with the Carbtune? Do I hook the carbtune hoses to the 5 way joint or directly to the starter valves?
Thanks,
Steve
Thanks for the info! I'm going to try it today. In the manual, I couldn't find the Tequila partMMOB said:Install a restrictor in each of the 4 hoses like the MCT directions say. Cut each hose about 4 inches from the end (that's 4 inches to you metric guys) and splice the restrictor in place.
Locate a hose on the ST1300 5 way tee which goes to a SV. Disconnect that hose from the 5 way tee and connect to one of the four channels on the MCT using the one of the pastic adapters in the MCT (or a brass two way barbed coupler purchased from Home Depot). Repeat until all four channels are connected.
Getting each hose off the 5 way tee is a bitch. Take two shots Tequilla and then use a small flat blade screwdriver to pry the hose off.
