In the middle of my top end rebuild, after extensive valve damage ( due to a collapsed water pump bearing ) , I'm replacing all the larger coolant hoses with superior multi layered silicone, but have a problem with the ' small bore ' pipes specifically the ones coming from the oil cooler, as Honda don't make them any more ! Does anyone know if using reinforced fuel tubing is safe for antifreeze, as the last thing I need is corroding hose internals killing the water pump. Have emailed a few company's including ' Gates' but no one even replies ? Have considered extruded silicone hose , but it's only a single layer and not reinforced, ( don't think it's suitable for sustained use with heat and pressure and antifreeze ).
Any help or info would be greatly appreciated
