Every bicycle rider learns it's easier to do balancing using just the front brakes. Keep the back pushing against the front.Every experienced rider knows you can't use much front brake in full lock circles but it's a breeze with this version of linked brakes.
Are the calipers still on your bike? Twisting the hoses like that does no harm?So A collection of wooden shims are used to move the pistons fully out (without popping them free). I also used the wooden shims to capture the skate lace,, as it was threaded around the pistons various ways. The results were quite good,,, and you kind of develop the technique as you go along. By using the lace in various ways,,, you can polish each piston completely around. Use more dot4 and the toothbrush to rinse the polishing product away. Then clean up the fluid with paper towels. Using this method allows you to not break the hydraulic seals (which would then require a full bleeding),, and not add any corruption to what might already be in your piston seals. It is not as good a full rebuild,, obviously. But so far the results are good this time around. Thanks to the guy who recommended the skate laces,,, cheers,, Cat'
So I popped in 3 sets of OEM brake pads today. But most of the work was in cleaning, polishing and lube. I used the skate lace polishing method that another poster here had suggested. My polishing compound was Autosol metal polish. It takes some old fashioned cleaning with an old toothbrush and some Dot4 fluid. A collection of wooden shims are used to move the pistons fully out (without popping them free). I also used the wooden shims to capture the skate lace,, as it was threaded around the pistons various ways. The results were quite good,,, and you kind of develop the technique as you go along. By using the lace in various ways,,, you can polish each piston completely around. Use more dot4 and the toothbrush to rinse the polishing product away. Then clean up the fluid with paper towels. Using this method allows you to not break the hydraulic seals (which would then require a full bleeding),, and not add any corruption to what might already be in your piston seals. It is not as good a full rebuild,, obviously. But so far the results are good this time around. Thanks to the guy who recommended the skate laces,,, cheers,, Cat'
Well - I wasn't sure, but it was worth asking the question to check. But you are right Larry.Good question John, however, if you notice the small center strip in your picture, you'll see that it is on the narrow side (back of caliper) and since you can see his, it means that the wider strip is hidden behind the pistons where it should be.
Thanks guys,,, the pads seem to retracting better,,, and the discs are running more evenly and cooler than before. The uneven wear between the previous pad sets, which was the original subject of this thread,,, should be improved. I am also retraining myself to do less trail braking (old motocross habit),,, and that should reduce rear pad wear rates as well. One curiosity though,,, on the front right caliper. As I was re-assembling it,,, I made sure the pistons were fully retracted (and that the spring clip was properly oriented),, also no dirt on the pad seat. But the new pads still did not open wide enough to slip over the disc. After several attempts,,, I removed the inside pad's backing shim (oem pads),,, which opened up the gap enough to slip over the disc. I rode that way for a couple of days,,, noting that my disc temps were normal,,, and that drag was minimal. Last night,,, I put the shim back in and it rides fine,,, with just a hint of "swish" from the RH caliper when you spin the wheel by hand. Has anyone else found new oem pads installs, that did not have the .7mm or so clearance at first ?? thanks,, Cat'Well done Cat.
I am talking about the shiny ant-squeal plate,, John. I don't think I have ever encountered a thermal shim on either end,,, and I have purchased and installed two sets of rear oem pads and a full set of front pads now ?? Cheers,,, Cat'I've never had problems with fitting new OEM pads and the anti-squeal plate, but the one time I tried fitting spare heat insulation sheets to the front, there was not enough room.
Oh well, worth asking anyway. All of my rear pads have come with a heat shield. Never the fronts.I am talking about the shiny ant-squeal plate,, John. I don't think I have ever encountered a thermal shim on either end,,, and I have purchased and installed two sets of rear oem pads and a full set of front pads now ?? Cheers,,, Cat'
If I understand this statement correctly it means;If the brake caliper slide pins are lubed and non of the caliper pistons are are stuck, you should be able to rotate a wheel by hand and not feel any brake drage. Then uneven pad wear, pad away from caliper pistons is caused by wheel torque that occurs with ytracking error and the necessity to counter--steer. The fix is to eliminate the necessity to counter-steer. Place the bike on center stand and adjust triple tree height with a level on the rear platform, to be level. You should find it is tilted downward, low side towards the front of the bike. Bill
Can you give me more explanation of this . I am confused . ThanksIf the brake caliper slide pins are lubed and non of the caliper pistons are are stuck, you should be able to rotate a wheel by hand and not feel any brake drage. Then uneven pad wear, pad away from caliper pistons is caused by wheel torque that occurs with ytracking error and the necessity to counter--steer. The fix is to eliminate the necessity to counter-steer. Place the bike on center stand and adjust triple tree height with a level on the rear platform, to be level. You should find it is tilted downward, low side towards the front of the bike. Bill
I realized that he hadn't been back in a while when I asked the question and so wasn't really expecting an answer directly from him. I came across this post when I was was looking for information on a related issue and found it a curious suggestion. I don't understand how the height of the front end of the motorcycle verses the rear end could have an effect on front brake pad wear. It is even more curious that it could cause more or less pad wear on one side of the front wheel versus the other. I was hoping that some one might have an explanation.He hasn't been seen for 6 months, so I am thinking...…...
