Interested to hear whether you guys managed to put them together again.
Today I removed the old carbs and took the Velocity stack off. That went very well, but putting them together again is indeed another thing.
Seems to me that the trick is to have all the carbs loose enough to have them move quite a bit from the rest. Then make sure all eight guides are in place at the screw holes.
Then fit them very carefully one at the time. When one fits in, fix it with the screws.
Only when all fits together nicely, tighten things up, starting with the velocity stack.
To anyone playing with the idea of taking the velocity stack off - Drop the idea, unless it's inavoidable. For normal carb maintenance this is not needed.
Regards, Rob
