Video of Gauges after Carb synch on 1997 ST1100 - good enough?
PhotoDoctor
Tampa Mike
Tampa, FL
ST1100/ST1300/Norton
Link to video:
At idle the needles all line up well - when I give it some juice the left gauge needle moves to it's own beat while the 3 others hang closer together.
I did the idle drop procedure after my first synch then did the sync process again a 2nd time.
I think this may be somewhat normal - I know there are a couple of very knowledgeable guys on the forum here and would like an expert's thoughts on this.
Thanks in advance.
the sync is typically done only at idle, so not sure if it means anything, curious to hear other opinions. If one cylinder is a bit 'looser' than the others it may not pull vacuum as well, dunno. If it pulls normally under load, I'd forget about it, no sense looking for a problem that doesn't exist.
Slydynbye
Will ride for Pie
Fremont, California
2000 ABSII
7331
It looks like the damping valve on the LH gauge is closed too far and it cannot react fast enough to changes in vacuum.
I was thinking that gauge is having problems. Maybe swap tubes to see if it follows the cylinder or the gauge.
Then my Wild guesses start
Did you check/adjust the valves before synching carbs?
Possible cracked diaphragm on that cyclinder?
Possibly adjust the idle screw to see of that helps.
kankakee
R1200rt
I have the same set. I get them to a point where the needles bounce a bit the set all the damper screws the same. I don't remember the number but made them all 1/4 turn out.
PhotoDoctor
PhotoDoctor
Tampa Mike
Tampa, FL
Same thing when I swap tubes. I have several bikes so I don't have to be in a hurry to button this one up.
Another thing I often do is pull each plug wire - one at a time and check the rpm drop. The cylinder with the odd gauge reading behaves correctly on this test. However, there is another cylinder that has a good gauge reading but has no rpm drop when I pull the plug wire.
Yes, I know I'm being picky but it's a hobby and I'm still looking for the 50 mpg ST1100 that I occasionally hear about :dr11:
Interesting, I had a KZ1000 in the early '80s that did that same thing and I never figured out why. The bike ran at full power so I never bothered looking any further. Showed it to a mechanic once, he couldn't figure it out either.
Mine has delivered 50mpg for the 24 years I've owned it, as long as I ride at 70-75mph or so. If I push it up to 80 then it drops a few. Now for the good part, I haven't done a carb sync in about 15 years. Never noticed any difference in 30 years of riding prior to that, tipped over my carb-stix and made it unusable, so I just quit doing it.
PhotoDoctor
PhotoDoctor
Tampa Mike
Tampa, FL
dwalby - This bike is the same year as yours, 1997 and generally gets about 43 mpg. I did get 50 mpg once when riding with a friend who would not go over 55 mph. I believe all the ST1100's in the usa after 1996 came with main jets of 125 and pilots of 38 and call for the idle screw to be 2 5/8 turns out. When I did the idle drop all mine ended up around 1 1/4 turns out. It also appeared that I had two carbs with leaky float bowl gaskets. Thus, when all is back together hopefully I will have improved the mpg's some.
