i was changing my air filter and decided to take my throttle body and cleaned up in there and also noticed under the heat mats that there were leaks around the thermostat housing and hoses. so i cleaned all that up and put it back together but was worried about debris falling in the intake so i put seafoam to try to wash it straight thru and i took the timing cap and rotated the engine. now that i assembled everything and started it a ton of milky ***** came outta the exhaust i only ran it like 30 seconds but did i rotate my engine the wrong way thru the timing cap? is my engine ******?
i did notice at first it acted like the compression was too much for the battery.
