So finally, after weeks of waiting for the right time, I took the bike out for the first short 100 mile test run, since working on the carbs. She ran great!
Couple days later I noticed that the front right disc is wet, not dripping but it had a thin film of something on it. I did not ride since that day. I did mention the “woody” feel of the front brake last year before the winter came. I did strip the calipers when I got the bike, as a part of the general: let’s see what we’ve got here” routine when buying a used bike. I remember replacing/installing the master cylinder rebuild kit as well as replacing the piston seals. Pistons looked ok then, so I didn’t bother replacing them.
I have yet to remove the caliper and try to pinpoint the leakage. The brake lever felt very hard to squeeze and the braking wasn’t impressive. Would a leaking brake piston seal cause a hard lever? Is there possibly something else, somewhere that would cause the brake piston seals to leak? I used a fleabay master cylinder rebuild kit but used Honda piston seals. I would welcome any ideas before I fork out $200 for new pistons and seals. TIA.
