When doing timing belt
I am now trying to install the Gates T325 belt - and it seems to be a hair too short. Has anyone else had this problem with the Gates? (I believe that I have the tensioner in the position that provides the most slack.)
When I installed mine a few months ago I couldn't get it to line up the timing marks perfectly. One way I was about a half tooth off in one direction, and if I moved it by a tooth then I was off by about a half tooth the other way. I fiddled with it and the cam pulleys for a while to see if anything would budge, and maybe got it just a little closer, it still wasn't perfect, but it was close enough. Its just a little off in the direction where if the belt stretches just a tiny bit over time then it will probably be perfect then.
If that's what you mean by a hair too short, then you're consistent with my experience.
And the bike runs perfectly since I changed it, so no big deal anyway.
STraymond
Cincinnati Area
'01 ST1100
8700
I mean that I can't stretch it to fit over the tensioner: applied to crankshaft gear, left cam gear - then right cam gear. Then even with a lot of tugging - the belt won't go over the tensioner.
Ray
Since you didn't mention it, the first question is have you removed the spring? IIRC I got it set first, then connected the spring to the post last, but my middle aged memory is fading on that. The only other thing is that you have to pull it pretty tight between every set of gears, make sure there's no slack at all.
STraymond
Cincinnati Area
'01 ST1100
8700
I have left the spring attached - but stretched to its limit and then temporarily tightened the tensioner pulley in the position that provides the most slack. I will attempt to tighten up between the gears - because if I can gain a 1-tooth movement, I should be OK.
Yeah, if you're off by 1 tooth that would probably be enough for what you're seeing. Also, since I replaced the spring and tensioner I think I may have held the belt in place and installed the tensioner last. So if all else fails and you're sure there's no teeth to gain, try that.
STraymond
Cincinnati Area
'01 ST1100
8700
Just an update: I did finally get the Gates belt on. It turns out that I did not have the tensioner spring at its absolutely lowest (most belt slack) position. I did have to struggle with the Left driven gear in getting the right starting position so that when the belt was pulled tight, the index marks would line up.
Thanks for the help.
Ray
West Michigan
'98 ST1100
8470
Concerning the tensioner and idler pulleys, can the bearings be replaced instead of the pulley assembly ? I have done this on auto belt pulleys. The bearings were standard sizes.
DeanR
finger lakes ny
1999 ST1100
7959
If anyone is having trouble getting the old belt off, unhook that spring. My tensioner did not reach its bottom position by pushing it downward, until I did this.
Regarding the spring, does it matter from which direction the bottom hook is attached? (as in possible interference withe the belt if the free end is facing outward)
DeanR
finger lakes ny
1999 ST1100
7959
New belt on, tensioner released, 51 teeth between cam marks (as when removed). R cam marks slightly off when others are aligned. Was perfect when removed....Does this look ok?
DeanR
finger lakes ny
1999 ST1100
7959
I guess you went with the Gates t/belt?
yep. Will this position be ok? If not, I don't know how to get all the marks perfect.
I didn't do the three rotations procedure yet but suspect that will not change the alignment of the marks.
It will not cause interference, remove the spark plugs and rotate the engine through to ensure there no issues.
I think the offset is caused by a different total length of the t/belt.
Dean that looks exactly like mine did, no matter how I tried I couldn't get that last little bit of mis-adjustment to go away. I think Martin may be on to something that the Gates belt is ever so slightly different in length, but it won't have any affect on how the bike runs. I don't know if the belt stretches a tiny bit as it breaks in, but if it does then the marks will only line up better, not worse, so you have nothing to worry about.
DeanR
finger lakes ny
1999 ST1100
7959
Have done the final procedure of loosening tensioner, rotating crank a couple times making sure all marks are still lined up (or 'almost'), advancing three teeth and tightening tensioner. At that point you can turn the crank as much as you wish before putting the covers back on, correct?
yep, crank away but watch the marks the first couple of revolutions just to make sure.
acedantinne
Easton,Pa.
04-st1300, 15-1200RT
#7224
Dean, that looks off 1 tooth to me? Per phone call= they should be right on the marks. I have yet to do 1 that was not. Now, they were all Honda belts, That should not make a difference?
If U look at your picture U can see U are off a tooth.
I will try to get up this week. Later BoB
Will bring Honda cam hold tool.
John OoSTerhuis
Life Is Good!
Bettendorf, Iowa
1991 SSMST1100
1058
Dean, if you counted teeth on the old belt and duplicated that during the new belt install the marks should align as before when the tensioning procedure is done. The belt will/should not 'stretch' in use.
Hmmm... whazat, Bob?
Regards, John
via iPhone 4S
