Hello everyone 2000 st1100 so when I’m up shifting to 2nd it usually goes in rough, as opposed to going into 3rd it’s smooth. Does anyone else have this?
I have owned two from new, a 1999 and a 2000. Neither one did it.Yes, they all do it.
I've found all the Hondas I've owned to have a much longer lever travel from first to second than higher gears. I've also found that my choice in boots is the cause of 'misses' when shifting from first to second. I also keep the ST's over 2500 rpm where the bike has some power immediately available for just in cases, maybe a bit higher depending on traffic behavior so subsequent shifts are no problem. Also keep the linkage clean and lubed.....it's down low and exposed to all manner of 'stuff'.The 1st to 2nd shift was rough, if I made the shift at low RPM’s. If I shifted at 4000, or up, it was much smother.
Ride baby ride!!!{hopefully everyone who replied will see this}wow you guys are amazing!! I thank you all for your input.i will be using full synthetic oil next change.im also happy that it seems to be a common thing among 1100,as im ready to hit the road for what could possibly turn into cross country trip across canada.
+1 @Andrew Shadow mine is as smooth as a hot knife through butter.
My bet would be the linkage. Take it off, clean it properly and re-lube.
Might be worth checking the brass clutch bushing as well.
Pre-loading will smooth it out but shouldn't be necessary.
Good luck.
Upt'North.
ok mine doesn't come out of gear, its just not as smooth as the rest.I have this issue on my '97 as well, and I have adapted my technique to keep the upward pressure on the shift lever until the clutch is fully engaged, and that seems to help reduce the number of times that it "pops out" back to N after upshifting.
hey buddy how are you? where you from?Ride baby ride!!!
Don't forget motorcycle oil only in your crankcase. After that ride on brother{hopefully everyone who replied will see this}wow you guys are amazing!! I thank you all for your input.i will be using full synthetic oil next change.im also happy that it seems to be a common thing among 1100,as im ready to hit the road for what could possibly turn into cross country trip across canada.
I’m fine, thanks for asking and as I posted (post #4) I’m about 45-60min from Montreal depending on which end of the island I’m going to.hey buddy how are you? where you from?
I will definitely do this.i did it on my tl1000s and it did make a difference.thanks+1 @Andrew Shadow mine is as smooth as a hot knife through butter.
Good luck.
Upt'North.
umm motorcycle oil only? what you mean?Don't forget motorcycle oil only in your crankcase. After that ride on brother
