Does a Spot need to be visible? If not, why not just stick it in a jacket pocket?
Uncle Phil, where did you get the little aluminum containers?
For best performance it needs to be pointing upward but in reality, in a pocket will work just fine.Does a Spot need to be visible? If not, why not just stick it in a jacket pocket?
The Donald Masters (RIP) scenario taught us that this isn't necessarily so.<snip> If you're knocked out a SPOT is not going to do you any good, unless some one is with you. <snip>
Thanks for the warning. Of course that could apply to my head also most days ...but I also think you'll periodically want to make sure they're screwed on tight.
:yes:
Nope I had had neither. That was part of my problem. I should have thought better. Things will be different next time. You don't think of these sometimes until you need them. I would use a SPOT for trips and local I didn't think I needed anything but will be better prepared. I don't know what they checked I was out and don't remember.I agree, a card in your wallet w/ICE info on it is also a very good thing to have, and so easy to throw together in 5 mins that it's almost ludicrous not to have.
Tim, any chance a wallet is all they had because that's all you had? Do you know for certain they didn't check your neck/wrists for ID or med alert info?
Yes you're right with this. If he had a last known location then it could have started there. I like my SPOT for the tracking mode. It leaves a footprint on where to start. I followed the search for him and prompted me to get a SPOT. My riding will be different when I start back.The Donald Masters (RIP) scenario taught us that this isn't necessarily so.
When I travel I'm always in tracking mode; and if I stop somewhere for more than just a few minutes I send an OK message at the beginning of the stop and usually the end of the stop. Family and friends who are following my SPOT track know that if I am at the same location for more than a couple of hours without sending an OK message .... well, something might be wrong and they should consider contacting the authorities to check on me. This would only apply to a remote location or where the SPOT is showing me off the road (not at a Dairy Queen parking lot ... for example).
I mentioned Donald Masters because it was that incident that prompted many to purchase SPOTs.
you can... I carry my on my belt under the jacket without to much tracking loss...( less than 1 of 10 track ). I used the slotted opening in the back to add a heavy zip tie and then added a clip so its easily removed.Does a Spot need to be visible? If not, why not just stick it in a jacket pocket?
I used a label maker to put my ice info on the back of my phone. Just my parents phone number and blood type, but with me thats all you need.I assume my cell phone either won't survive the crash or is password protected so I do have ICE info there but it won't be accessible.
