where to buy thermostat and help on strip down.
cambridge united kingdom
pan european st1300
Hi guys where can i buy a thermostat from for my pan 1300 been looking ebay and google cant seem to find anything please.
ive managed to order a new ETC switch which should be here this week,
im having the issue of the fans not cutting in
and once the heat has gone up in the red with the flashing light
luckily just as i got home
history of the bike is its only done 200 miles in the last year so i am thinking something is jammed up possibly thermostat
and probably gammy connections on the switch.
i also here that there is an awful lott that has to be taken off to do this job.
did i read somewhere that someone has a PDF on how to do this job....
Many many thanks Gary.
PM an email address and the PDF is yours.
pan european st1300
Thanks guys is that a stateside shop. Been very busy not done bike yet moving house at moment. Does anyone know what sort of miles par gallon i should be looking at fuel wise the miles per gallon s dosnt seem very high
mlheck
Ft. Wayne, IN
'18 BMW K1600GTL
664
I went from a normal mixed roads MPG of 42 down to 36 when my thermostat starting going bad, but I am a little heavy with the throttle so your mileage may be different.
pan european st1300
thanks STooray, im just a bit confused about the fuel economy gauge
it reads 7.5 sometimes 10.5 is this miles per gallon or litres the manual dosn't say it just say's what the gauge is
Mark
Gotta make tracks
Moderator
Apache Junction AZ
KTM 525exc
3768
It depends on what you have it set to display:
Avg fuel kilometers per liter (this is a guess as I suspect you have your bike set to display kilometers).
or
kilometers per liter figured every ~20 seconds.
Which do you have it set to display?
Montreal
2009 ST1300A9
Because you are in the UK it can be miles per litre, kilometers per litre or litres per 100 kilometers depending on the model of ST that you have according to the attached page from the 2008 Honda Pan European owners manual.
pan european st1300
ah ok guys now changed it and it looks like miles per litre so now I need to figure out how many miles I am doing per tank
so I need to look up how many litres the tank holds
kool thank you fellas.
Gary
Montreal
2009 ST1300A9
Honda says 29 litres. How much the tank holds really won't help you determine your fuel consumption. Fill the tank up so you have a starting point. After that every time you put gas in the tank record the miles ridden since the last time you put gas in and record how many litres you put in. Miles ridden divided by litres consumed = your consumption in miles per litre.
pan european st1300
riding home last night she was cruising along 70mph and reading 14.01
higher the speed obviously the less the numbers lol thats all down to throttling lol
Essex, UK
2005 ST1300A
I've run mine to past the 300 mile mark, but not recommended as it's not too good for the heart! I usually fill up at around the 250 mile mark and there is still more than a gallon left in the tank.
pan european st1300
17553916_10211062478651211_7207848352979665549_n.jpg17629889_10211065523087320_6729396857885532730_n.jpg17629765_10211062092921568_617859741216628640_n.jpgstriped the pan yesterday and replaced the thermostat which was stuck open. also replaced the fan switch so now the fans work
replaced oil and filter also adjusted balance shafts and got to say its way better on fuel sounds so much better and no more overheating
