I have a 2006 st1300 and need a 4 way plug for my trailer i pull.Where is the best place to get?Thanks
You'll need a universal isolator harness - the electrical connection link above is a good place to start.I do not know where i need to wire up my plug in.
Most motorcycle trailers require at least a 5 pin plug unless you install a brake run adaptor. L turn R turn Brake,running, ground. I use a simple 5 pin flat trailer plug.I have a 2006 st1300 and need a 4 way plug for my trailer i pull.Where is the best place to gey?Thanks
There is a pretty good color wiring schematic in the Articles section, that may aid you in determining which wires connect to the tail, brake, and turn signal bulbs.What i do not know is what wires i tie on to on my ST1300.
