28amp VRR temp measureements
Nor Cal
2005 ST1300A
I am going to instrument my VRR (28 AMP) to get some temp data on it in different cooling configurations.
Yes it might be lost hope - but i'm a thermal engineer and well you know how it is!
Does anyone have a cross section picture of the VRR (internal component layout) or understand the physical construction. I need to understand this for strategic placement of the TC's.
My guess is there is a PCB (populated with caps diodes, FETs) mounted to the aluminum plate and then potted a polymer. The best case for heat transfere out would be that the heat sources are thermally conducted to the aluminum plate.
Anyway - any data would be helpful. If I new the exact components we could get real scientific and determine the MTBF as function of temperature then correlate that to the temp of the components - ok I've gone to far again for this project. But that's what we would do in the thermal design process to establish the design criteria then design a thermal solution (cooling) to meet that criteria.
Thanks,
Paul
Rather than monitor the temperature of the unit itself (I'm sure the rectifier/regulator's heat sink was designed to handle the heat produced by the alternator continuously putting out it's full rated 28 amps while riding across the Sahara Desert) I think it would be more informative to get a thermocouple as close as possible to (or even into) the two connectors nearest the alternator . . . . the field connector with the black and white wires and the stator connector with the 3 yellow wires - I suspect that more failures of the alternator and/or regulator are due to electrically dirty connectons within those two connectors. The weakness of the design is that those 5 wires all carry lots of current so even a tiny bit of resistance in a dirty connection will create heat, making the connections even worse. If you sense temps significantly above ambient at either of those connectors, I suspect you're going to see a system failure before too long
Don
I like this concept - 4th TC added to the mix. Well that only allow me to get temp data on a single conncetor - i'll think more about this.
All this, may not change the game, but at minimum it will answer some questions.
Thanks for the thought on this.
Don
There has been a fair bit of research on this in relation the VFR, so doing a search on that may help. Someone went through various cooling methods with temperature measurements. From memory a cooling fan from a computer worked well.
