Article [13] ST1300 - Getting to Throttle Bodies
Admin-dude
2025 Miles
002627
Pat (1st1300)
is putting some great stuff in his album.
He's letting me post this for him based
on those items.
  • Step 1
    You also do this procedure to replace your FPR with Turbo Tom's FPR , also
    to install Audiovox CC and balance throttle body's. Hope this helps
    attachment.php
  • Step 2
    Raise tank and prop up with rod provided
    attachment.php
  • Step 3
    This will allow you to remove the top of the air box. Be careful not to drop
    the front 2 screws into the space between the airbox and the tupperware.
    attachment.php
  • Step 4
    Air intakes and air filter exposed.
    attachment.php
  • Step 5
    Remove the air filter note the tangs you have to bend up to remove the
    screws holding the air intakes to the housing. You can use a small impact...
    attachment.php
  • Step 6
    Next remove the screws holding the bottom of the air box.
    attachment.php
  • Step 7
    Lift the air box base and remove the front hose.Note: The hose has to go
    back in the retainer when you reassemble.
    attachment.php
  • Step 8
    Next remove the hose at the rear of the airbox base.
    attachment.php
  • Step 9
    Your throttle body's are now exposed.
    attachment.php
Re: Getting to Throttle Bodies
Suppose you just wanted to look at them.
As stated in Step 1 - This is the procedure you'd use if you were replacing your Fuel Pressure Regulator or installing the Audiovox Cruise Control. So, it should be helpful for someone that has never done this.
Great work to show how this is achieved. Don' t have a need at the moment, but I hope when I need to work on some new (to me) area of the bike there are some instructions as clear as this available.
