Article [13] ST1300 - Reinstalling Rear Wheel
This is awesome for us noobies! I have everything going back together and ground to a halt when reinstalling rear caliper I cant seem to get brakes open enough to slide over disc. Is there a trick to getting it back on? Any suggestions welcome. I did try to use a screwdrive, one end would open for the other to close.
Sometimes you have to wiggle it some to get it over the disc... I've used the screwdriver many times to just get the pistons open a hair more which is all it takes. It helps if you can get a small piece of wood on between the pads on one end while using the screw driver on the other as the pistons will push in on one site as you're pushing the other side... Always remember to never touch your brakes between teh time you took the caliper off and putting it back on.
Wood shims (available at any lumber yard) work perfectly to hold the pads open and/or to pry them open.
Went out to attempt to work on the brake, but after being in the heat all day, I just could not do it. I taught the range part of MSF class this am and am DONE!
Great instructions, hope you don't mind, but I integrated the text and the pictures into a MS Word file and have the file saved to a Google Drive.
Link to Google Drive Files (viewing)
If not "kosher", I'll remove the link.
Thanks again for the extremely succinct and helpful write-ups.
Mike
Mike
No problem Mike. Just add my name to the credits and include this line the very end. "Now I am going riding, while you all reinstall your rear wheel. Mine is done." Thanks for marrying up my text to the pictures. Hope it has been a help to others as it was done about 5 years or so ago.
Done.
Great source of info here.....thanks kindly. Just purchased an 07' and in the process of changing all the fluids as well as rear tire. Having this info was a god send. Nice to know that you are doing it correctly when you are working on your own ride.
What is best to clean old moly off pumpkin
I did mine a couple of days ago. I used contact cleaner and small bits of rags. I cut up small pieces as one wipe and I tossed it into the garbage.
Use latex or equivalent rubber gloves as this is messy.
So, spray a bit of cleaner onto the rag, now using a flat blade screwdriver (or similar tool), stuff the rag in between the gear teeth, rag becomes dirty, toss it and start all over again with a clean rag.
Also, I have heard of people using Q-Tips also.
The only thing I would of liked to do is rotate the gear teeth in the pumpkin. Not sure how to do this with the rear wheel off. I was thinking about making a star like tool, insert it inside the gear teeth to rotate it.
Another way of rotating the pumpkin gear teeth is:
Remove the final drive spline from the rear tire. Insert, the final drive spline into the pumpkin and rotate.
It easier to clean the teeth in the pumpkin if they are near Bottom Dead Center
Old thread for sure but one correction I think necessary. Chuck says to use LocTite Red to secure the caliper stopper bolt.
Honda branded HondaBond Red in picture is removable at a later time with appropriate force but LocTite branded Red formula is not removable later without heat or inappropriate force on a steel bolt threaded into aluminum. I think most of use use the word Loctite as both a noun and a verb and most of us DIY'ers should know Loctite brand Blue formula (removable) is what to use on the stopper bolt if you don't have a tube/bottle of Honda Pro Chemical Red on hand.
Re: ST1300-Reinstalling Rear Wheel
Rod, Just been through it all again with the schematic. I have all parts in correct except no's 22 and 23 which state o ring. but cant see them doing much. Anyhow, the collar is in there.......the Honda Dealer is in agreeance but why when i torque it up it pulls across to th ediff that much that it fouls the plastic guard and i cannot freely spin the wheel...the bike will be going soon if i cant solve this........had enough of th edam thing already!!
Hi There , what is the finding eventually to your problem here, as I am experiencing similar issue and looking for some lesson learn from all senior owner ST1300 here, If you do not mind to share, I really appreciated.
Did you go into the wheel and check the bearing for the drive flange? That is the next article, Other than that I agree with Old2wheeler, it has got to be one of the spacers. Check and make sure the spacer in the drive hub (diff) is seated properly. Sometimes if gets stuck. make sure it is not in back wards. Make sure you have the spacer on the left side of the wheel seated properly. Hard to diagnose with out seeing it. Good Luck, let me know what the solution was.
Hi Chuck, I was wondering if you get any feedback to your suggestion here? , I would really appreciated if you may share, as I am experiencing similar issue and trying to figure it out
Good write up and photos and was on the fence between the blue and the red loctite. Just one last pitch for any feedback before I finish my reassembly this morning
I've just replaced rear pads and reinstalled the wheel and only snugged the stopper bolt and axle nut to do an initial wheel spin test. With my rear caliper off, I can get a spin of about 2 1/4 rotations, in place after a SMC test and release [by hand] I can get about 1 3/4 rotations. This after relubricating both caliper slide pins, SMC pivot bolt needle bearings and SMC clevis bushing.
At disassembly, I wiped the existing film of grease off the axle bolt and did not apply any yet.
I've got some concerns about how much clearance there is between the swing arm and the axle. My photo with the light in the background makes this clearance appear greater than it is and once the swing arm to wheel spacer [whatever it is] gap of maybe 1/8 to 3/16" closes [before applying any significant torque] it [axle perpendicular to swingarm] doesn't move.
I'm guessing the film of grease on the axle is to provide lubrication for a couple of seals, and everything else; spacer, inner bearing races, ect should get locked up in place with the shaft.
I'm wondering if it bears mentioning to avoid getting any grease between the last bit of the axle and swingarm bore.
Installing rear wheel on a ST1300.
Disclaimer: This Photo essay is not a replacement for the service manual. My goal is to maybe enhance ones understanding of the service manual and make it a bit easer thru some of my pictures. At no time do I recommend relying solely on these photos and my instructions. As a wise old instructor once told me "RTFB square." Enjoy, good luck.
Photo 1. Clean old molly off of wheel hub and pumpkin splines.
Photo 2. Lube pumpkin splines with Honda Molly
Photo 3. Lube wheel hub with Honda Molly ( be some what liberal but don't over do)
Photo 4. Install wheel into pumpkin making sure wheel splines mate with pumpkin splines. Might take a couple of try's to get them to slide in.
Photo 5. Clean axle
Photo 6. Grease axle with axle grease. DO NOT use Molly for this.
Photo 7. Slide axle into pumpkin side and stop before axle exits wheel on left side. Axle should slide with only hand force. DO NOT use excessive force. Might have to jiggle wheel a bit.
Photo 8. Inspect brake pads at this point and make sure there is enough space between pads to install caliper onto disk.
Photo 9. Work caliper on to Disk and align axle hole, and hand push axle the rest of the way through. Do not over force.
Photo 10. Honda says to replace Caliper Stopper bolt, because of the lock tight from the factory. I use the same bolt after I clean the old lock tight off and reapply a new coat of red lock tight. Works for me. You make your choice.
Photo 11. Apply a couple of drops of red lock tight to caliper stopper bolt.
Photo 12. Install caliper stopper bolt.
Photo 13. Set torque wrench to 51 ft lbs. (If you are going to do maint. on your bike please get a descent torque wrench)
Photo 14. Access the caliper stopper bolt forward of the muffler above the cat converter, and tighten to 51 ft lbs.
Photo 15. Install axle nut.
Photo 16. Using a 27 mm 6 point socket for tightening axle nut. IMGP1457r.jpg
Photo 17. Set torque to 80 ft lbs and tighten axle nut to 80 ft lbs.
Photo 19. Re-install lower rear fender
got my rear wheel off, cleaning her up while tire is en route, dunlop roadsmart 4, one on the front too, caught a screw in the rear and plug finally wore out and won't hold what a disappointment,
BUT GREAT INSTRUCTIONAL ON REASSEMBLY, thank you
was shocked at the gunk buildup on that rubber that rides inside the pumpkin edge,
getting the tire mounted and balanced at a regular tire shop for $40 tire cost me $265 from amazon cheapest i could find, overseas was cheaper but $100 delivery!!
Glad you brought this thread back always good to refresh the process.
Question about your screen name, you had to put a 2? Is this a popular screen name out there?
