Here is the reply from England. I think it sounds like a good way to go but for now because of time constraint I just ordered one from Honda. I am not worried about failure of another while on a trip. I have been riding it all over with the hic up syndrome and it never caused any major problems. If it happens again though I think this route woud be a good way to go.
We take payment at https://
www.PAYPAL.com
We also take all major Credit / Debit Cards [Visa/Mastercard/Amex/Solo/Maestro]
Don't know the EXCHANGE RATE?
Check it out at
http://www.XE.com/ucc
NRP Carbs and Diaphragms
Unit 2,
Station Approach,
Victoria Station,
Manchester,
ENGLAND,
M3-1NY
Tel/Fax: +44 (0)161 832 8646
Out of hours answerphone
Hi Thomas ,
Thank you for your enquiry Re: ST1100 diaphragms
Yes we have diaphragms in stock for your model, we now make these in
completely synthetic Viton rubber, completely inert and resilient to modern
fuel containing 10% and more alcohol [Ethanol].
Our material is certainly as good as, if not better than original Honda
The Viton material is slightly denser than OEM, and we have reduced the thickness marinally
We normally supply diaphragms re-fitted to your original slides [so you
would send your slides over to us]
That is the ?fitted? price listed, this service is a tried and tested
method we have used for 15 years. All original rings re-used, and the
finish is exactly as original.
GB ?34.00 each X 4 = ?136.00 Priority return Airmail GB ?10.00= ?146.00
Just remove needle from base of slide and send them to us
WRAP SLIDES INDIVIDUALLY TO AVOID DAMAGE TO EACH OTHER
Turaround would be 2-4 days from receipt
If you need other parts please advise
Float bowl seal GB ?6.00 each
Needle valve and seat GB ?10.00
Air cut-off diaphragm [on side of carb] GB?12.00 each with spring/o-ring
We are increasingly being asked to supply loose diaphragms.
If you feel this option is for you, it would save some time/cost
Dis-assembly of the slide is NOT necassary [or recommended]
If you want loose diaphragms we can supply these at -15% [self-fit discount]
So, GB ?34.00 -15% = ?28.90 X 4 = ?115.60
Priority Trackable Airmail GB ?8.50 Total GB?124.10
I can send you fitting hints/tips, it is not too difficult
Dis-assembly of the slides is not necassary
It re-fits back in between the plastic rings like the original
Please advise which offer you would like to take
I can send you a Paypal payment request if you wish
Credit cards also no problem
Regards
Andy
PS. GB?1.0 = USD$1.55 approx
Loose diaphragms are shipped within 48 hrs of payment
