Article [13] ST1300 - Brake Bleed Procedure [VIDEO]
  • Thread starter Thread starter Mayhemmarty
  • Start date Start date
Mayhemmarty
I made a short video that may help anyone out trying to bleed the brake system.
Hope this is helpful. search youtube "st1300a brake bleeding". I made a short one.. about 50 seconds and a long one... about 9 minutes (sorry).
Just a little note... With the vaccum bleeder it is possible to pull small bubbles thru the threads of the bleeder stem. Easy fix is to teflon tape the threads at the time of a full bleed/change.
( btw, not needed when pumping only )
Great job, I would just add for 1st timers that Step 3a is crucial. Right at the base of the p in caliper is the nodule that has to be at 12 O Clock. To get it right I finally had to bleed it at 1 and 11 O Clock to get the air out of there after a SMC replacement. This would have been a great help if I had found it. My question is how do you keep that bike so clean? Do you steam clean it or something?
Ron
This is excellent, I appreciate your effort to publish this!
If it's helpful, I found I could get to the PCV bleeder without removing the right fairing. After raising the tank I was able to get a wrench on the bleeder from up above and I got a hose onto the bleeder from underneath, through the side hole in the fairing.
Dumb question. The video on bleeding the PCV mentions "pumping the secondary master cylinder". He also mentions pumping the front and rear brake lever and pedal. How do you pump the SMC? Is that not done by operating the Front and/or Rear brake lever/pedal?
Scott
I'm a bit confused about the SMC. Is this just on the ABS equipped models or all ST1300??
Nice work on the video and instructions.
No, the SMC is part of the Honda linked brake setup and is on all ST1300s regardless of ABS or not.
Thanks for the video, finished flushing my fluids today. All went well, replaced rear pads. Front pads are still great, I am going to wait a few months and check them again. Old brake fluid was very brown compared to new. Found several rust/crud flakes in the old fluid. Hardest part was removing the plastic to access the proportioning valve.
If I may ask a dumb question... what is the PCV? I know that as Positive Crankcase Ventilation, but here, I assume it refers the Proportioning Control Valve. Is that right?
I had never heard of an SMC (secondary master cylinder) before. What is its function?
Yes you are correct about the PCV. It divides rear pedal pressure between front and rear calipers with a bias toward the fronts.
The secondary master cylinder provides pressure to the rear caliper when the front brake lever is applied. It is the mechanism that Honda uses to link the front brake to the rear brake. There is no shared hydraulic circuit to do this but rather a mechanical one. The left brake caliper is mounted on a bracket that pivots on a lug on the lower left fork slider. THe SMC is on the top of the left front caliper bracket and is aligned fore and aft with a short clevis and pushrod that fixes to a second lug near the top of the fork slider. When the front brake lever is applied the LF caliper pivots forward a few millimeters and since the pushrod is fixed in length it applies pressure into the secondary master cylinder. Pressure is sent to the rear caliper when the front wheel is turning and the front brake is applied. The front wheel has to be turning.
If you don't mind lying on the floor next to your motorcycle you can test the SMC action. Lay down with your head toward the front in such a way you can push the rear wheel with your right foot, causing it to turn. While pushing the rear wheel, reach up and push the left front caliper forward. It won't move much, a few mm, but in doing so the center pistons in the rear caliper will press against the rear disk and stop the wheel from turning (applying brake).
Great explanation. I can understand that. Thanks.
Have to admit, I listed to and watched this video about 3 times to get his 'front caliper, drivers side/passenger side down pat.
