I am getting ready to change my stuck thermostat. Is there anything speacial to flushing the system or do i just pour distilled water in the radiator and then drain that.
The bolts that drain the block are a little difficult to get to but not as bad as some have said.
I followed anothers advice from prev threads and leave on the cap, slightly/slowly pull bottom hose and the antifreeze dribbled out, didn't splill more than a few drops.I had the coolant flowing into the pan until I rmoved the radiator cap, then it showered my garage wall
... If doing just a coolant change or thermostat replacement follow general flushing practices or the service manual or I can send you an excellent step-by-step tutorial that appeared here 6 or 7 years ago. It is designed to step you through the ST1300 coolant and/or thermostat replacement. It is easy...
PM sentI'd like to see the article, as my bike is coming up on coolant change/flush time.
It is a good idea to have the radiator cap removed before you pull the hoses. I do not see how you can do it without a little mess.
Make sure you clean up the Kitty coolaid or your neighbors cat might get into it. :sm1:
I plan to do a coolant change soon, possibly this weekend, since mine is waay overdue. I did a coolant change w/radiator removal, flush, etc. a few years ago when I had to replace the sticking thermostat, so don't have any plans to remove the radiator this time around unless I encounter something that might make it worthwhile to do so. I need someone to refresh my memory regarding the flush procedure. IIRC, I think I followed someone's suggestion to use a 50/50 mix of distilled water & white vinegar to fill the cooling system, run it up to operating temp until the fans kicked on, let things cool down, then drain & repeat with 100% distilled H2O before putting in the recommended coolant. Does this flushing procedure sound familiar to anyone? I think I would prefer this method over using an automotive cooling system flush product from O'Really or AutoZone, especially if it would be gentler on the ST and equally effective. Any suggestions?
Thanks, Don
What did you do? Delete all your posts about the importance of replacing hoses and clamps at the first or second service or other low mileage?After removing dozens of frozen, stuck and corroded thermostats from members bikes, I would strongly suggest replacing the thermostat everytime you flush the coolant, or once a year, which ever comes first.
I've found them failing in as little as 2K miles!
I change mine yearly as a precaution.
I have alot of folks tell me their T-stat is still in good working order...it only takes 15 minutes to reach three bars!
Then I remove and show it to them![]()
I
put a couple drops of PB blaster on the end of the hose,
.02
