I have read on various posts about running 'sea foam' in tank of petrol as remedy for carb problems. I have never heard of sea foam and was wondering what it is or what it does?
Thanks in advance
Ian
Thanks in advance
Ian
Wow, some crazy stuff over in that thread. Dumping it straight in the throttle body while running sounds like it could have unpleasant results that may lead to a Darwin Award. Must say I'm a little intrigued with the DIY aspect being the cheap old fart I am. I worry that the manufacturing process may include a process beyond "add ingredients and mix up".Seafoam MSDS
A good discussion of what Seafoam constituents are: http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=269397
I'm 47 and, amazingly, have never had carburetor problems so I've never had a chance to work on them. I've seen them disassembled and have a basic understanding of how they work, just no hands-on.It depends whether someone is dumb enough to just upend a bottle in the intake. Dripping/drizzling it in is the way to go. No different than using carb/choke cleaner while the engine is running.
I find out that the ST1300 calls for premium gas after running a tank of regular through it: "probably ruined...." subdued LOL.
Also, is Seafoam a "magical" product that sounds good on paper but really doesn't do anything?
... does Seafoam dissolve these deposits instantly or near-instantly when applied at full strength through the carburetor? Spray carb cleaner is cheaper and seems optimized for the job. Was all this so they wouldn't have to pull the carbs and clean them properly?
Dumping it in wholesale would pretty much flood the engine. As Jim said, a little drizzle is the way to go.
I don't know if the carb throats on the 1100 have the same coating them that the 1300's throttle bodies do (I doubt it), but you definitely want to avoid exposing it to Sea Foam, which will eat it.
--Mark
