BakerBoy
It's all small stuff.
Re: ST1300-Valve Adjust, Left Side
I missed this one before... great job Mark! :yes:
What ever happened to hydraulic lifters.
:tools1:
Great photos, and sure appreciated your help when we adjusted mine! BTW, I still have the other half of your shim kit, which I can never remember to get back to you: .
I'll update the original posters post-this is an old one.Great write up. Going to check my clearances right now. By the way, it would have been nice if you had given the correct valve clearances instead of making the viewers look them up. It's a small thing but it would have been nice. I believe the correct clearances are intake .16 +/- .03 mm (.006 +/- .001). exhaust. .25. +/- .03 mm. (.010 +/- .001)
Thanks for documenting this so well! Super helpful!![]()
While performing the 48,000 mile valve check, I discovered one valve out of tolerance on the left side of the bike. Data from the prior two checks indicated the valve was moving tighter at a rate of 0.01/mm per 16,000 miles...and yes, it had moved out of spec by the time the 48,000 mile check rolled around.
I proceeded with the adjustment of the valve(s) on the Left side of the bike. Luckily, this is the 'easy' side to adjust since you can easily get to the Cam Chain Tensioner. While I was in there, I nominalized any other Valve that was getting close to the edge of tolerance.
Attached is an overview of the Valve adjustment on the Left side of the ST1300.
EDIT 5/28/13 - Photos of the right side adjustment can be found in my picture album (https://www.st-owners.com/forums/album.php?albumid=4010). Right side is performed essentially the same as left side with exception of accessing the cam chain tensioner screw (detailed in photos).
The correct clearances are:
