ST1300 oil filter removal
SPX
San Diego
This weekend, I will be doing an oil change on my ST1300. I've looked under the bike, and the process looks straightforward, but removing the oil filter looks like it may have a trick. I'm not concerned about spilling oil, as I think I can mostly prevent that. I'm more concerned about the access to remove and install the oil filter. This is a bike where a lift looks like it would be helpful.
Searching on here, it appears that some take off the lower fairing, near the side stand for better access. Others say, no need. It appears to me that to torque it properly, the lower fairing may need to be off.
So, lower fairing on or off for oil filter removal and install? Any other pointers would be much appreciated!
Montreal
2009 ST1300A9
No need to remove any fairings. I find it easier to reach in underneath from the right side of the bike. Tighten the new filter up by hand and you will be good to go.
970mike
Mike Brown
Lompoc, California
07 & 12 ST1300A
SPOT
LINK
8057
Put the bike on the side stand, take a piece of foil and cover up the exhaust and lower plastic remove oil filter from right side. If it is real tight you may need an oil filter wrench to remove old filter.
Rindge, NH
I never understood why some have problems. Yes, the filter is in kind of a tight spot but it's not too bad. I put it on the center stand; drain oil; remove filter with a small strap wrench from the left side of the bike; install new filter hand tight; fill with oil. Shoot center stand with brake cleaner to get off the few drops of oil that will get on it. Done, 8 minute oil change (or less).
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
Not that I haven't removed a few oil filters in my day, but the one reason I spend the extra bucks on K&N 204 Oil Filter is so I don't have to worry about getting it off!
If you have a filter cap wrench (the little dohicky that fits on the end of the filter and allows you to use a wrench to take it off), that will save you sometime.
My procedure for doing my oil change is to Centerstand the bike and drain the oil. after it is draining and the drips slow down enough, I push it to the sidestand to drain the rest.
I then put the bolt and washer (new washer if you prefer) back on and then attack the filter with the bike still on the sidestand.
First is to place the foil over the left exhaust, near the filter. Then use my 17mm ratchet wrench and unscrew the filter (VERY EASY to do with the K&N 204 filter! :D pull it out Watching where the oil drips ...
Clean up the filter mount, a little oil or grease on the o-ring on the filter (K&N come pre-lubed) place the new filter on and tighten down to spec...usually use the 17mm to push it 3/4 turn.
Remove the foil, centerstand the bike again, and put in one gallon and 5 ounces of Chevron 400le (I think that's the stuff...it's in my garage....)
Clean it all up, put it all back together and I'm done within 30 to 45 minutes.
SPX
San Diego
I completed the oil change today. It went fine, with no issues. The whole thing took about twenty minutes, most of which was used up waiting for the oil to drain into the pan. The other time consuming part was refilling the oil; I need a funnel that bends. The regular funnel I have requires oil to be added slowly, due to the angle of the fill part.
Had a bit of trouble getting the clips to clip in on the cover, but I'm sure that will come with practice.
I was surprised that the oil smelled pretty badly when I drained it. I have heard of this before, but have not experienced it. I'm unsure if it's indicative of oil in need of changing, or just how it is...
DixieFlyer
Terry Melton
Fayetteville, GA USA
2004 ST1300A
6774
+1 I maintain the all the family vehicles (4 cars + 1 pickup truck & 1 motorcycle) and the ST1300 oil change is straight forward -- have had no problems in 45,000 miles. I use Purolater Pure 1 filters and bought a good quality metal end cap style filter wrench. EZ enough -- takes me longer to put away my tools and pour the used oil into the container than to do the actual oil change. The only vehicle I have that is easier to change oil than the ST, is my wife's Chrysler van with the 3.6 Pentastar engine. It has a cartridge type oil filter on top of the engine, so just remove the cover, replace the cartridge, and replace the cover -- no mess no fuss and takes about 1 minute. Drain & replace the oil -- good to go for another 8000 miles.
Regards,
Terry
Eastern Ontario
'05 ST1300
Use a HiFlo Filtro HF204RC filter. No messing with filter wrenches!
It has a 17mm nut on the end. Easy-peasy. High quality filters and priced right.
Put a pan under the centre stand.
No side panel removed either. More a less easier than my ST1100.
houston, tx
No ... what you need is one of these funnels and a bungee cord. Loop one bungee hook thru funnel's hangar eyelet, then attach other hook to clutch lever, then stab funnel into fill hole.
Now you have a sturdy hands-free "fill system" that's also at a height for easy pouring.
Louisiana
2019 GL1800
8659
The ST1300 is one of the most efficient engines in the world, oil changes on this bike can be performed at much higher miles than Honda recommends. I’m a certified aviation mechanic 38 years and do all my own maintenance on all my vehicles, I find a great high mile oil is Rotella T6 full synthetic changed with filter every 10,000 miles.
Erdoc48
94/00/04 STs, FSC600
20201104_094201-01.jpegI
I like that! Maybe next time I’ll do that- I actually have one of those funnels.
