Inner cowling fairing removal
Alief, TX, USA
7461
Re: Inner cowling fairinf removal
Refer to touringmotorcyclists.com and you will find a fairly good write-up on fairing r&r that should help you.
010688
Remove the 6 rivet pins and 1 screw that retain each one then slip them out toward the ground. Behind the right one is a connector for the temperature sensor that must be disconnected when you can slip your hand behind the cowl.
I suggest you use the Tuperware Worksheet - its located in 'Most Replied Tech Articles' to store the fastners. I printed the pages and glued them to blocks of wood then drilled holes where the screws are stored so everything is held securely.
When you put the inner cowls back, insert the fasteners in the numbered order and leave the screw loose. You may have to wiggle the plastic to get the last one or two plastic push pins in place.
Alief, TX, USA
7461
I've aways found it much easier to leave the sensor connected, just remove the screw that secures it to get it out of the way when removing the cowl. The connector you're referring to has never been disconnected on my ST since I've owned it.
010688
I never though of removing the sensor from the cowl but it makes perfect sense but it's also easy to disconnect the sensor which I've done many times.
Exeter UK
Pan 1300A
Plus always check the two inner panels slip under the top part ( by the cubby holes ) nothing worse than putting in all the poppers and finding the panel on the outside--- Do these fixings first
T.U.D.
