It's got 99,250 miles. OP stated he did the fork spring change at around 80,000.
+1. I weigh 210 lbs. When I put .95 Race Tech springs in my ST I had to set my preload/sag to my weight by adding spacers. I would bet that at 165 lbs you'll need to remove some spacers. According to everything I've read, you want 36 mm sag for the ST.Check rider sag front and rear, are they correct? Maybe too much pre-load?
See my updated post concerning the target rider sag.+1. I weigh 210 lbs. When I put .95 Race Tech springs in my ST I had to set my preload/sag to my weight by adding spacers. I would bet that at 165 lbs you'll need to remove some spacers. According to everything I've read, you want 36 mm sag for the ST.
Check you sag to see if you need to remove some spacers. If not just the oil change should work.
while you are sitting on the bike so your weight is being factored into the sag measurement.Take the bike off the stand, and let the bike settle into the suspension.
Just to clarify did you set your front fork preload with 36 mm or is that your rider sag number?Well, after a120mile ride I am quite pleased with the results of the work I've done. No more rocking front to rear and a much smoother ride.
Still performs great in the twisties.
Here'a summary of what I did:
Rebuilt front forks with new bushings, seals, and ss-7 fluid.
Verified they indeed have .90 racetech springs and filled to correct level.
Set preload to 36mm.
Refilled rear shock adjuster and set preload and rebound.
Thank you everyone for your assistance!
Yes, less preload equals more sag which gives you a softer ride but compromises your suspension travel. Meaning that you will be more prone to bottoming out. You will also have more fork dive when getting on the front brake.Just curious about something: Does more rider sag equal a softer ride?
