sendin
Denny from Sebastopol
Got a 2002 non ABS recently and finally put together the maintenance history from the previous 2 owners. I think I know what I should do, but more eyes and sometimes even more opinions are usually helpful! So thanks in advance.
MILEAGE DATE SERVICE
0 5/28/2002 NEW
620 6/12/2002 600 MILE SERVICE OC, O/F BY ORIG DEALER
4755 7/27/2002 4K MILE OC, 3.9 QTS PENNZOIL 10-40W, O/F FRAM PH6017A, PLUGS CHECKED & GAPPED 0.032"
8153 10/26/2002 8K MILE OC, 3.9 QTS PENNZOIL 10-40W, O/F FRAM PH6017A, NEW NGK CR8EH-9 PLUGS CHECKED & GAPPED 0.032"
12799 7/26/2003 12K MILE OC, 3.9 QTS PENNZOIL 10-40W, O/F FRAM PH6017A, PLUGS CHECKED & GAPPED 0.032", AIR FILTER
15843 11/22/2003 15K MILE OC, 3.9 QTS PENNZOIL 10-40W, O/F FRAM PH6017A, PLUGS CHECKED & GAPPED 0.032"
17416 6/17/2004 NEW REAR TIRE BRIDGESTONE EXEDRA G548 160/70-17M/C 73V, NEW REAR BRAKE PADS,
18954 7/26/2004 18K MILE OC, 3.9 QTS PENNZOIL 10-40W, O/F FRAM PH6017A, PLUGS CHECKED & GAPPED 0.032"
21108 4/23/2005 21K MILE OC, 3.9 QTS PENNZOIL 10-40W, O/F FRAM PH6017A, PLUGS CHECKED & GAPPED 0.032"
" NEW FRONT TIRE BRIDGESTONE EXEDRA G547 110/80-18M/C 58V, NEW FRONT BRAKE PADS
21270 5/5/2005 NEW PLUGS IRIDIUM NGK CR8EHIX-9 GAPPED 0.032"
25035 11/13/2005 24K MILE OC, 3.9 QTS PENNZOIL 10-40W, O/F FRAM PH6017A, PLUGS CHECKED & GAPPED 0.032", REP FINAL DR 80-90W
28326 8/20/2006 27K MILE OC, 3.9 QTS PENNZOIL 10-40W, O/F FRAM PH6017A, PLUGS CHECKED & GAPPED 0.032"
28921 9/30/2006 NEW REAR BRAKE PADS, REP BRAKE FLUID (DOT 4) FRONT & REAR BRAKES ONLY
29140 11/2/2006 NEW AIR FILTER
31539 10/24/2007 30K MILE OC, 3.9 QTS PENNZOIL 10-40W, O/F FRAM PH6017A, PLUGS CHECKED & GAPPED 0.032"
" REPLACED COOLANT, (PRESTONE 50/50 MIX) REPLACED CLUTCH FLUID (DOT 4)
31892 3/8/2009 NEW BATTERY
32070 4/16/2009 NEW REAR TIRE BRIDGESTONE EXEDRA G548 160/70-17M/C 73V
33307 4/17/2011 NEW BATTERY
35558 8/6/2011 OC, O FILTER, COOLANT, RAD CAP
40466 8/9/2012 OC, O FILTER, FINAL DRIVE FLUID, USED MOTUL 20-50 SYN, GEAR LUBE
? 11/16/2012 REAR BRAKES
? 6/28/2013 CLUTCH LINE, BRAKE FLUID
42781 10/23/2014 Current mileage
So I was going to do an oil change, new oil filter, flush and put in new coolant, new brake and clutch fluid, check brake pads, new spark plugs/gapped, new air filter, replace final drive oil, clean and regrease splines on final drive, and for front forks new seals and oil. I was also thinking about carb sync and valve clearances, but that might be above my current pay grade these days; maybe not. I should probably get a nice stand and then all this stuff gets 10 times easier. Denny from Sebastopol
0 5/28/2002 NEW
