wjbertrand
Ventura Highway
Bob, I borrowed this summary from Annas Dad (post #83 in this thread) and added a few things:
Additionally, I've distilled the various components that have been investigated, and found to not be at fault:
I'm probably forgetting a couple of things.
- Engine Stop Switch – Clean & Inspect
- ABS Module – Clean & Inspect
- Tachometer Circuit – Inspect
- Ignition Coils – Swap Out
- Battery & Ground Connections – Clean & Inspect
- Throttle Position Sensor- Replace
- Engine Control Module – Swap Out
- Side Stand Switch - Clean & Inspect
- Spark Plugs - Replace
- Spark plug wires tested for resistance and connection at cap end renewed (cut off 1/4" and screwed cap back on)
- Crank position sensor replaced
- Camshaft position sensor replaced
- MAP sensor replaced
- Fuel pressure regulator vacuum port checked for leaks found OK
- O2 sensors disconnected, computer memory cleared and test run "open loop" no difference, stumble still present.
- All vacuum lines inspected, 5-way T cleaned and inspected
- All accessible harnesses and connectors inspected, connectors opened, inspected and cleaned. Nothing suspicious found
- Clutch switch replaced (but I don't think this is related anyway)
- Ground wire points on frame inspected, cleaned & tightened.
- Swapped out fuel cut relay.
