Another option for the ST BF Goodrich G-Force Comp-2
970mike
Mike Brown
Lompoc, California
07 & 12 ST1300A
SPOT
LINK
Here is another option for you Darkside riders on an ST 1300.
I searched all of the current tires out there and found this tire which looks like a good one as the sides are already slightly round.
I will keep you updated on my findings and mileage. It will get a break in ride on Monday as I am heading to NatSTOC.
Here are a couple of pictures of the tire.
Sent from my SM-G900V using Tapatalk
That is a nice looking tire Mike. I look forward to the final mileage report. Maybe I was a little hasty picking up a spare Yoko Avid!
What happened to the Pirelli? You can't have that many miles on that one.
--Never mind. Saw your other post.
Sounds like a very good tire. Does handle well at speed and how good is it holding up as for tread wear?
This tire handles very good at low speeds and triple digit speeds, I have over 5000 miles on this tire and it looks like new still.
Mike you very nearly have me converted...
I am very happy with this tire as the wear seems great so far, it handles well, and the cost was great.
I like this tire so much that they will be going on our Honda Accord when it needs tires.
Mike, after burning up my rear tire riding two up in 5000 miles, I'm taking your suggestion and will try the BFG. I've already switched the front to a Bridgestone BT45. I' hoping this setup will give me a good two years of service. I'll let you know how it works out for me.
I am very happy with this tire so far. I hope it works for you.
On your recommendation alone, Mike, I just bought one of these and will be pairing it with a Pilot Active. I'll save my cupped BT-45 to reverse for next time.
I just pulled my rear wheel and although I haven't yet mounted this tire on the wheel, it doesn't even come close to fitting in there!
Are you sure it will squeeze down enough (about an inch) to fit in there when it's mounted?
I thought the same thing with the new GYTT. I had to grind about .030" off just at the swingarm casting centerline. I also loosen the 4 bolts in the "pumpkin" to let it slide outwards and a milk jug cut plastic section over all the inside of the pumpkin for sliding the tire across the pumpkin.
The tire is in and mounted, but it rubs on the swingarm. I have free rotation for about 1/2 revolution, and then it binds pretty hard on the other 1/2 revolution.
Do I have an alignment problem of some kind that can be fixed? Otherwise, I guess this is coming off and I'll get another Hankook.
I think each swing arm must be different thicknesses as some have rubbing issues and others don't. You could flatten out the area on the swing arm where it rubs like others have done.
