Ok.. so far so very good.... First round of questions:
Thanks
- When you tighten the alt gear nut onto the shaft.... how tight do you tighten it? There is that big flat washer (spring loaded because of it's shape?). Do I Loctight the shaft and tighten the nut down snug? or very tight?
- When replacing the new alt, the tin cover... the alt won't fit unless I remove that cover? Or will it?
Thanks
