The service manual calls for Honda Dot 4 brake fluid and does not mention an equivalent is okay too. So, does anyone think there is a risk with the abs system in using an Auto Store branded Dot 4 brake fluid?
That is an interesting chart. Wonder why the price of Dot 4 fluid varies so dramatically from brand to brand with walmart Prestone 12oz at the lowest $3.87, Pro Honda 12oz at $4.99, and Motul 600 16oz for $18.25?Not an issue using store brand DOT4. Like oil brands, DOT4 brands do have some subtle differences and there are only a few with incompatibilities. But what's important is to do the fluid change.
An example comparison.
Unless they're selling it out of a 50 gallon drum, rather than a sealed container, I wouldn't think time on the shelf would matter.Thanks for the quick replies. Going with an Auto Store Dot 4 brake fluid saves me time and money.
Honda Dot 4 fluid in my local motorcycle store shelf is 2-4 years old so the only way I can get fresh fluid is through ordering it from a store with high product turnover on Dot 4 Honda fluid. With an internet order I have to pay for shipping and wait for the order to arrive.
Now, that's clever! Good tip!FWIW I alternate flushes between Valvoline and Prestone brands. I'm doing at least 1 change a year sometimes 2 and the color difference between these brands is makes it easy to see when new fluid is coming out the bleeders. One is nearly clear and the other yellowish.
Mark, I'm replying to your post because I know that you're very knowledgeable of Honda ST maintenance requirements, etc. I hope I'm not stealing the OP thread, but I'm prompted to ask another question pertaining to brake fluid. I've been using Castrol GTLMA (Low Moisture Activity) brake fluid in my motorcycles for several years. When I took my brake calipers to a trusted Honda mechanic ~2 years ago to have them reconditioned w/new seals installed, I showed him what I was using for brake fluid and he advised me to bleed it out of my brakes ASAP and replace it with conventional DOT4. I never did follow his advice, as I thought he may have assumed I was using DOT5.x fluid, which I know is a no-no unless specifically approved and/or recommended by the M/C manufacturer. The label states that it is synthetic brake fluid that exceeds DOT3 & DOT4 specs, but does not indicate that it contains any silicon or any reference to DOT5. The label also states that it meets specifications SAEJ1703, J1704, FMVSS/CMVSS No. 116, which means nothing to me. Bottom line, is this brake fluid bad for my ST, or good?The ABS system is just another passage the brake fluid passes through. It doesn't require any special treatment; if your brakes work, so will the ABS (at least from a hydraulic standpoint).
--Mark
You could use Dot 5.1, just don't use Dot 5.I never did follow his advice, as I thought he may have assumed I was using DOT5.x fluid, which I know is a no-no unless specifically approved and/or recommended by the M/C manufacturer. The label states that it is synthetic brake fluid that exceeds DOT3 & DOT4 specs, but does not indicate that it contains any silicon or any reference to DOT5. The label also states that it meets specifications SAEJ1703, J1704, FMVSS/CMVSS No. 116, which means nothing to me. Bottom line, is this brake fluid bad for my ST, or good?
Where's the "Like" button.I have been using Prestone or Valvoline DOT 4 in my bikes and cars for 25 years. Auto store fluids are just as good as any MC dealer equilivants. Same for oil, oil filters, valve stems, coolant, waxes, polishes, cleaners, brushes, the list goes on......
My opinion is that specific, motorcycle branded consumable fluids are a big rip off. Harley is the worst offender, in my experience.
