Uncle Phil
My biggest is 18" and there still 'outward' adjustment holes.
Good to Know Phil. thank you sir! I would figure I will be OK with the 21 inch then.My biggest is 18" and there still 'outward' adjustment holes.
"Handles rims from 11 in. to 25 in. diameter" according to Harbor Freight- see here.
Scootac and I shoe-horned a pair of Bridgestone T30 tires on his ST1300 the other day. After the struggle I realized NoMar doesn't make tire changing equipment. They make exercise machines thinly disguised as tire changers though.
Nice work....I'm getting inspired here! I had thought of this, but other projects beckoned. I used a recip saw to get my last tire off, and tie-wraps to mount it. Worked ok, but I'd love to give this a go.
Thanks for the ideas!
Here is what I came up with on the dismount end.
If I can find a correct size pipe, the steel stock will be welded into the correct size pipe.
If I had a 3 foot long piece of 3/4 stock, that would be nice too, I could drill a 3/4" hole into a piece of 3/4" square stock, to form my mount end.
But I don't think a 3/4" steel stock will pass through my spindle.
That is the trouble with that lathe.
Now, I don't know yet, but I may end up with a dis mount bar,
AND a Mount bar. Don't matter to me.
